diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Finished: Proac 2.5 active xo - Click HERE for Original Thread
tiroth
Well, it took a fair amount of work, but I completed my active xo project.
For some background on the design, check out this thread:
http://www.diyaudio.com/forums/show...p?threadid=8541
I was initially targeting crossover points at 1500Hz and 3800Hz. My simulations indicated that a good fit electrically was about 2000Hz and 4000Hz, and I was told that 1500/3800 were the xover points in the commercial design.
However, despite the dreaded "hump" at 2kHz, there was not enough response in the 2000-2500Hz range resulting in a suckout. I then tried crossing at 2000 and 2500Hz on the low end, which did fill in the gap in the 2-2.5kHz region. I still had a suckout at 3.2kHz. To fix this, I tried moving the high pass crossover point down a bit. Unfortunately this was not successfull; as predicted in simulation, there was a significant hump in the response at 1kHz, and the suckout at 3.2kHz was only slightly ameliorated!
At this point I was grumbling a bit; however, I started to look at Jacq's published measurements on the Proac clones and noticed that I had achieved nearly identical acoustic response in one of my trials. (Jacq: Thank you for publishing tweeter and woofer as separate measurements!)
I then referred to the Stereophile review of the commerical speakers (http://www.proac-loudspeakers.com/stphres2.htm) and the in-room response was nearly identical to my measurements: flat to about 38Hz, suckout at 3.2kHz, rise in response from 5kHz-10kHz, fall in response from 16kHz-20kHz. (Note that the anechoic response of this speaker was very flat despite these in-room measurements)
I then concluded that this xover arrangement was very, very close to matching the passive version.
Final xover points:
LP 6dB @ 1500Hz, 12dB @ 2500Hz
HP 18dB @ 3800Hz
You can see below the actual in-room measurements of 1500/3800, 2500/3800, and 2500/3000. I think the remaining "error" in the response needs to be solved by fixing the room and/or speaker placement, which is beyond the scope of this xover project.
Final note: ^_^ Although I built a passive xover for subjective comparisions, I didn't trust it very much for measurements because I used junkbox parts and high DCR coils. The active and passive xovers do match fairly closely.
tiroth
Crossover components:
2n5457 as a buffer, biased at 1.3mA (CCS)
SLA battery supplies
Dale resistors
Wima FKP in the HP sections
Also Wima MKP and ERO 1813 in the LP
Distortion is about -85dB 2nd harmonic SE, which of course disappears entirely when the differential output is used. 3rd harmonic appears to be way down in the -100dB arena. Noise is certainly under the noise floor of my test equipment.
I am using Rod Elliots SLA charger design:
http://sound.westhost.com/project98.htm
Initial listening impressions: the bass is even tighter in the active version. Complex passages seem cleaner. Imaging is very, very good.
Click here for a (large) pic of the complete unit:
http://www.anidian.com/imgs/xover.jpg
Or one of the boards. Each board is a single differential channel. I didn't want to do any Diff - > SE -> Diff type conversions, nor did I want to use something like a diff. pair here, so I simply duplicated the circuitry. I matched each differential "pair" of circuits to 0.5%. Over the entire range they track within 0.25dB, which is about as far as I trust my measurement setup.
tiroth
P.S. That dreaded 2kHz hump is gone. I think this is validation that at least a good bit of the hump is due to electrical interactions between the driver and the passive xover. The active version is immune to these problems.
mikek
...excellent engineering all round old chap...:nod:
tktran
Am looking foward to your Construction article on this active XO. Actually I built a P3A with the help of your excellent website.
Page generated in 0.029120922088623 seconds with 17 queries,
spending 0.00685024 doing MySQL queries and 0.02227068 doing PHP things.
