diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Chassis - Click HERE for Original Thread
weinstro
Somewhat related to the recent thread on heatsinks, what do you all recommend for chassis?
I'm quickly coming to realize that the most daunting aspect of a DIY effort is the mechanical layout and chassis design. So, I'm looking for some suggestions for nice quality steel chassis.
One approach is to scavenge the chassis of a suitably sized dead amplifier. But even dead amps on e-Bay can command quite a few bucks as many bidders seem to hope that the seller is an idiot and the only thing needed to resurrect the amp is to replace a fuse.
Thanks in advance for any insight.
Rob Weinstock
JasonL
Chassis For what..! A aleph or something..
weinstro
Sorry -- I should have been more clear, I suppose...
200 watt per channel, Class AB stereo power amplifier.
Thanks.
LukasLouw
Page 3 of the August issue of Nuts and Volts has a Halted Specialty ad. Look in the far right column, 3rd item from the top.....
1U rack chassis, 2 for US$19.95. If interested, make sure to mention the Nuts and Volts ad, as teh online price is $19.95 each.
I ordered a bunch just to have, the price is certainly right :)
The order taker was kind enough to get one from the warehouse when I asked him quations about condition and holes, doesn't sound too beat up. Apperently they've been gutted of whatever electronics was in them, with small 3 lights on the front panel, a bunch of holes for BNCs, RJ45s and so on, on the back.
www.halted.com HSC#19437
Lukas
bmcevers
If you don't mind paying a little more, sescom.com has some nice rack mount aluminum chassis for under $100.
saurus
I've had great luck with these folks - new 3u units for $60 - $70.
www.par-metal.com
sam9
Definately take a look at HSC as mentioned above. I live about 10-15 min from the shop. They often have a pile of surplus comm units stacked out frot (old routers, switches etc). I bought one for $20, took out all the insides except for the power entry module, tore off the front plate ang replaced it with piece of aluminum. Voila! A very well constructed amplifier enclosere.
I don't know if Illl ever need it but, kept the power supply because the transformers look like they may be useful some day. If that's the case, then I will have an indusrial strength enclosre for a net cost of zero.
tiroth
Thanks for the HSC deal. Best thing I've seen since All Elec had those Alesis rackmounts. These look to be in worse shape, but are bigger, cheaper and almost a blank slate, so I'm calling it even.
LukasLouw
Well, I received the 4 chassis from HSC Yesterday, and they're a little beat up, no dents or such, but lots of scratches on teh top plate. Can't say that I'm disappointed, as they only cost me about US$13 each with shipping.
Lukas
cowanrg
what exactly can you fit into a 1U case though? its much too short for any of my projects...
jeffry_widjaja
if u look for professional amps look and will spending more money for cosmetic you can look at www.atisearch-anodizes.com
great success:bigeyes:
Page generated in 0.027972936630249 seconds with 17 queries,
spending 0.00703907 doing MySQL queries and 0.02093387 doing PHP things.
