diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Antex soldering iron? - Click HERE for Original Thread
Tor M
Hi:)
I really need to get a new solderin iron and have been looking at some irons from Antex. The price is right, and money is a limiting factor.
Have anyone tried soldering irons from Antex and if so, what are your experiences?
Tor Martin:)
fmak
Excellent - recommended
Thomas
I use a cheap antex iron (20 W I think). I got 3 different tips for it, and they work exelent. One thing: the tip get stuck to the iron if not removed an re-inserted priodicly. I once destroyed an iron trying to remove the tip.
jcarr
IME, an Antex is one of the better economy-grade soldering irons that you can buy.
hth, jonathan carr
Tor M
Hi!
Thanks for answering.
A local store sells an 50 w iron with adjusteble temperature from 200-450 degree for about 67 $. Thats alot cheaper than a solder station.:)
It`s the same as this one:
http://www.en.rs-components.no/cgi-...prodoid=7416994
Maybe I`ll go for it.
Tor Martin:)
Page generated in 0.021435022354126 seconds with 17 queries,
spending 0.00851417 doing MySQL queries and 0.01292086 doing PHP things.
Please support our sponsor.
