diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
20 output distribution amp - Click HERE for Original Thread
biff584
I'm trying to build an audio distribution amp to split a 4v line level audio signal from a car cd player into about 20 outputs- I work in a store selling car audio equipment and need the distribution amp to demo power amps. I remember seeing a schematic here recently with 4 outputs- pretty simple opamp circuit. Would something simple work for as much as 20 outputs?
Thanks.
Brian.
mrfeedback
A couple of Gain Clone chips each with 20 x 100 ohm build-out resistors would do the job just fine.
Eric.
purplepeople
quote:
Eric.
I imagine that the unit is needed so that each power amp can be punched in/out for in-store ABX.
Wouldn't it be easier to get a patch bay, with the added benefit of no actives in the signal path?
:)ensen
millwood
quote:
Thanks.
Brian.
yes it would. I think either TI or National has a schematic about a distribution amp. Just make sure that you get a stable op amp at unity gain.
mrfeedback
Err, yeah I'm not sure if the LM GC chips are unity gain stable.
If not, there are TDA series amplifiers that will do the same job.
I have seen a broadcast DA that used a TDA series chip - I forget which one - TDA 1521 maybe.
Switching is a pita construction-wise if a constantly distributed signal to suitable, and more expendive.
Eric.
millwood
my understanding is that distribution amps are NOT power amps. their job is to essentially split input into many outputs, drive the signal over a reasonably long distance and terminal at a power amp (thus the name).
so you aren't going to use power amps for this.
mrfeedback
Typical DA's provide a means of driving multiple device inputs from one signal source.
One metod is to provide say, 20 opamps each driving an individual output, another method is to to resistively split the output of one amplifier stage that is capable of driving said 20 loads.
Resistively splitting the output from one amplifier provides guaranteed uniformity of the signal, and the resistors ensure that if one output is short circuited the remaining 19 signals are unaffected.
Normal broadcast and PA usage is one amplifier with resistive splitting.
Using an integrated power amplifier provides economical and appropriate output voltage and current capability in one package.
Eric.
moamps
For example?(1in8 or 1in16 with one amp and resistive network)
BSS?LEICH?AKG?RANE?SHURE?SYMETRIX?BERINGHER?
biff584
Thanks for the replies everyone. Can someone direct me to one of the schematics from TI, national, or some other schematic showing a resistive splitter distrubtion amp?
Thanks again.
Brian.
millwood
Thanks again.
Brian.
I am not sure exactly what "resistively" mean. I guess it is simply putting a large resistor in serial with the load and hang it to the output of an amp in parallel with other loads.
I would you will find this types of distribution amps from TI or National as it discourages the sales of their products.
millwood
Eric.
Eric, I am sure that a professional audio engineer can make a DA out of a power amp if s/he had to.
But I am not sure how good that kind of a DA is.
First of all, in a typical design, the signal out of a DA is to be power amplified remotely before going into a speaker/speaker array. so what a self-respecting audio engineer wants to power amplify an attenuated signal from another power amp?
plus, it is quite difficult to find a power amp that's unity stable - I don't know one.
and if you work out the math, it is quite tough to design a resistor network that will work (reasonably well) for a large number of outputs.
BTW, no resistor network by itself will assure you of unaffected performance in case of a short in one or more channels: a amp with low / no output impedance will do that.
for the incredible price/performance ratios of op amps, it makes little sense to use one power amps vs. multiple op amps for distribution amps.
I hope DA manufacturers think the same way. But what does a dumb bank know about electronics, right? :)
moamps
[B]Thanks for the replies everyone. Can someone direct me to one of the schematics from TI, national, or some other schematic showing a resistive splitter distrubtion amp?
"some other schematic"
On each output place R=100-150R
moamps
quote:
[/B]
Noise figure is poor.
quote:
for the incredible price/performance ratios of op amps, it makes little sense to use one power amps vs. multiple op amps for distribution amps.[/B]
Correct. Also, DA have mostly balanced outputs, and tracking between + and - output must be very good.
True.
millwood
Eric.
Eric, I was going through another thread (the mic preamp one) where somemone mentioned Rane. Playing around their site, I found the following schematic:
http://www.lashen.com/vendors/Rane/da-26.asp
It is down towards the bottom. to my untrained eyes, it shows 6 channels each driven by its own op-amps.
Granted, I am not a sound engineer and haven't seen a distribution amp in person and you seem to be in this profession. but do you know of actual distribution amps using power amp (chip or otherwise) to resistively split the signal? I would love to know.
millwood
here is a link to BB's TL082 datasheet. On page 18, there is an audio distribution amp using TL084.
it has a 3 separate opamps buffering on the output, similar to the Rane distribution amp.
Page generated in 0.073585987091064 seconds with 17 queries,
spending 0.03285813 doing MySQL queries and 0.04072785 doing PHP things.
