| Matttcattt |
| i need some advice on the wiring of my 6 channel car gainclone using 16 chips. it will have 2x parrelleled and bridged, and 4x bridged. i have attached an image of the amp. should i have a star +v, and star-v? how should i run the signal connections? the red boxes are power, blue is signal, green it speaker out, yellow are the chips, and grey is the heatsink. |
| Matttcattt |
| if people did not understand the question, i would like advice about where is should run the wires. i was thinking of running 4 solid wires from the front to the back (one above each row of chips) and running all the wires along these, dropping wires down to the chips. i then thought that having signal, power and output wires running parellel may cause a problem. any help is appreiciated. |
| Matttcattt |
| when he says: "4) Starwire the positive and negative PSU lines to the chips using ideally twisted pairs of reasonably heavy wire, do NOT buswire the +V and -V lines." does he mean have a star +v and -v, and not to daisychain the chips, or the complete oposite? |
| Matttcattt |
| ok, i will need +v, grounf, and -v stars. how should i run the signal and output wires? should i run all the cables to the sides of the case? power and output on one side, and signal on the other? |
| Mad_K |
| quote: | Originally posted by Matttcattt
That sounds like a good plan. Have you read the twisting thread? Also; shielded signal cables (coax) helps alot. |
| Matttcattt |
| yes, i have, but i'll read it again anyway. |
| Rarkov |
I was planning a gainclone for the car but the +- PSU seems prohibitive...What is your solution?
Gaz |
| Matttcattt |
i am going to have 2 seperate car batteries to power it. i will then have to charge these every so often... :scratch:
have a look at my website. |
| carlosfm |
i need some advice on the wiring of my 6 channel car gainclone using 16 chips. it will have 2x parrelleled and bridged, and 4x bridged. |
Woooooooooooooowwwww...
You'll better tape all your widows.
I've seen a back window jump because of a guy that was testing his new sub.:devily:
Is that a "KrellClone"? ;)
You may find on the market some 12v to 24v converters (switching PSUs).
Use two to get +/- 24V. |
| Rarkov |
Where did you get the Case from? That's quite cool!
Gaz |
| Matttcattt |
everyone seems to like the case :D i found it in a skip :cool:
i will post some better quality pictures soon, as i have a new camera.
Rarkov, i just had a look at your website again, to see if you have any internal photos of your gainclone, and you do have one, but the new flash "viewer" wont let me see the last photo, and all the photos are only thumbnails when clicked on, and they do not enlarge. |
| purplepeople |
Hi Matttcattt,
Cool case.
It looks like you are using industrial components in your case. The side look like machine profiles, the top is some kind of perforated sheet and the fronts look like alum sheet anodized aluminum. Are the rack mounts just 90deg profile aluminum?
:)ensen. |
| Rarkov |
;) It didn't work very well!
I've got Notepad open as I type developing an ASP/Access gallery system...Bare with me...
Gaz |
| Matttcattt |
| quote: | Originally posted by purplepeople
Hi Matttcattt,
Cool case.
:)ensen. |
yes, the sides are extruded aluminium, the top (or bottom) is perferated aluminium sheet, the front and back is sheet aluminium, and the rack moutnts are just 90deg profile, yes.
| quote: | Originally posted by Rarkov
Gaz |
will do :d |
| carlosfm |
Hey Matttcattt,
I'd like to take a look at your famous case, but I don't have the link to your site.
Can you post it?
Thanks. |
| Rarkov |
carlosfm:
Click on the WWW link underneath his posts... |
| carlosfm |
carlosfm:
Underneath his posts I only see this:
If it aint broke, don't fix it.
(and my own bit)
If it is broke, fix it.
(and more)
If you can't fix it, take it apart and see how it "worked".
Do you see more?:scratch: |
| Rarkov |
And under that - on the blue bar are two images:
Email WWW
Gaz |
| carlosfm |
Email WWW
Gaz |
Under that I can't see nothing on my screen.:bawling:
Some problem here?
I can see your link perfectly, Rarkov... |
| Rarkov |
| Can you not see the "Quote" checkbox at the bottom right hand side of every post?! The links are one the same line...Some kind of bug?! Can you post a screen dump?! |
| carlosfm |
I deleted all the temp files and the cookies and still the same.
How I miss MS-DOS.:devily:
Here's my screen: |
| amoeba86 |
| In the gap between the 2 posts there is a space seperated by 2 bars in between them is the "WWW" button. |
| carlosfm |
:eek: :bigeyes: :bawling:
My ears are working perfectly, but it seams I'm getting blind.
Sorry guys, and thanks. |
| carlosfm |
Yes, the box looks very nice, but will it fit in your car, Matttcattt?
Oh, and please, change that red led for a blue one.;) |
| Rarkov |
Not a problem m8...
I'm sure we've all done far worse! ;) |
| Matttcattt |
| quote: | Originally posted by carlosfm
yes, i may have to alter the centre column, or mabye the glove box.
i may do, it would match the colour sceme. :rolleyes: the place i buy most of my electrical components from sells blue LEDs for £1.50! :eek: i can get some for ~60p, but with only one item, it seems stupid to pay postage for one LED. :clown: |
| carlosfm |
Buy one for each chip and put them all gloing.:clown:
You'll be able to read the map at night.:devily: |
| carlosfm |
Buy one for each chip and put them all glowing.:clown:
| carlosfm |
| deam, the post got duplicated.:eek: |
| Matttcattt |
maybe i should buy a white one instead... :idea:
lol i've done that :att'n: |
