| Decent, reasonable GC caps/resistor survey: - Click HERE for Original Thread |
| GrahamnDodder |
First of all, many thanks to all the advice givers out there. I have read and read and read (my wife hates you guys by now, I think) and surely bypassed a lot of dumb mistakes (and possibly minor explosions) that I would have made. Thanks especially to decibel dungeon, Hennesey's pages, and certainly Peter, who has been more than generous with his GC advice.
Like a lot of people, I am building my first gainclone. I am going for the Plitron toroidal trafo and MSR860 diodes, probably 1 trafo with the separate grounds going out to each channel. That looks an elegant solution to the problem of one vs two trafo's, while probably going a long way to avoid the potential grounding issues with the single version.
I am building the PSU on a pine board first, testing the holy bejesus out of it, then crossing my fingers, covering my eyes and hooking it to AC. If she don't explode, my next step is to dip my toe in the GC amp waters. I have LM3875 samples (4) coming from Singapore. So I have "one to give," so to speak, as I can try it out for cheap with the first two chips. BTW, I have built a CMoy headphone amp (not a total noob, but certainly no expert,) and am going to try to wire the GC short as possible P2P. If you are gonna embrace the short-path philosophy, why not go whole hog? If I screw up I can always etch a PCB and start over for what I have in the amp section, $-wise. Which leads me to my question.
Not being a gourmet cap/resistor guy, I need to know which is a good set of decent-but-not-terribly-expensive garden variety caps/resistors. I would hope to get something commonly available at Mouser or Digi-key. The idea is not to make a drastic mistake while not spending too much. Sort of the Toyota Camry of the genre.
Caps are (2) 1000 uf's, the 1 uf from pin 1 to 4 and a 2.2uf input cap.
Resistors are 10k input, 22 output, 220 feedback and something (18? 20) from 7 to ground.
Especially would like to hear from people who did not break the bank on these parts and were still very pleased with the sound. Also, if I am going to splurge, where should it be? (Please, God, not the 1000 uf caps... :bigeyes: I would like to get a reasonably priced GC to work before I trusted my experience to those humongously expensive BlackGates.)
Please name names, and be as explicit as possible with the genus and species. For Chrissakes, wading through the caps section at Digikey is worse than getting sent to the grocery story for panyhose for my wife! Too many choices I know nothing about...
Thanks in advance, and when my GC is at long last finished, I promise plenty o'photos. I am by trade a photojournalist and will not be able to be stopped from sharing the baby pix.
Muchas gracias,
GnD |
| mhennessy |
Hi Graham,
I don't know what Digikey are like, but RS and Farnell in the UK sell wide ranges and it can be tough to decide how to choose between them. So, to help narrow down the choices, I look for the following specifications:
Rated temperature - go for 105C over 85C
Manufacturer - choose a recognised brand such as Panasonic, Philips, Rubycon, etc. Most suppliers stock extremely cheap caps from brands I've never heard of - you tend to find these in the cheapest and nastiest of consumer equipement
Lifespan - these are normally quoted at a particular temperature, and the relationship between life and temp is non-linear. As a rule of thumb, reduce the operating temperature by 10C, and you'll double the lifespan of the cap. Other factors are involved, but the running temperature of a bit of kit certainly is important. When comparing between different brands, be sure you're comparing at the same temp.
Impedance and ESR - caused by imperfections inherent in the construction and manufacturing processes. You'll want to select for lowest.
So, look for high temperature, long-life, low impedance/ESR in the specs. You tend to find that these things are related to cost. These properties are desireable in any capacitor, but for a switched-mode power supply they are essential. So, look for caps that are suitable for use in SMPS...
All of the above is just standard good practice, but won't tell you anything about how the cap will sound. There's no spec to cover that, but I would say that from an engineering perspective, the close a cap gets to being "ideal", the more likely you are to get good sound quality from it. So, pick a few different ones based on the above guidlines, and try some listening tests.
You'll notice that I didn't put numbers to most of the specs above - this is because they vary according to value and can size. You'll have to do your own research to get a "feel" for matter. You might like to start with Panasonic FC's - I chose these for my preamp a couple of years ago based on the engineering reasons given above. I was pleased to discover that people have been using them in their GainClones and other projects, and think that they sound good.
So you see, engineering might not have all the answers, but it can get you quite close ;)
Sorry - you asked for simple recommendations. I'm not very good at those - I'd rather give you the tools to make an informed choice... But the Panasonic FC's are a safe bet for the 1000u's because they're good quality and not too expensive. I'm sure you'll recieve some more exotic recommendations from others here, so once your GC's are working you can easily try some comparative listening tests.
For the resistors, Nuuk recommends RN55C's, which you can buy from Farnell (are Digikey connected to Farnell?). He's found them to sound better than normal metal-film resistors. I haven't "auditioned" them yet, but I have used them before for applications that are much more critical than audio :rolleyes:, and they are certainly excellent technically. I intend to use them in my final GainClone constructions, as they are not too expensive.
The only thing that I'm not sure about is the input cap. It should be non-polarised, but Farnell don't sell much in the way of decent non-polarised electrolytics.
So, not exactly what you asked for, but I hope it helps,
Mark ;) |
| Nuuk |
Hi Graham,
I dread the day I get a feedback form back from Decibel Dungeon from an angry wife/partner/girlfriend! :eek:
As Mark said, I am a big fan of the Welwyn RC55 resistors if you can find them on your side of the pond. They sound very good without being painfully expensive.
For the decoupling caps, the Panasonic FC's are very good for the price. Arguably, the next (significant) step up from those are the Black Gates and then you WILL have to ask a friend to order them for you so the SOH doesn't see the bill!
Polypropylene is my choice of lower value caps but many feel that you need at least 4.7uF on the input of the GC. That's why Peter Daniel went for Black Gates. I also use Black Gates but have used 47uF for two reasons. One, because I already had them in my parts box, two because they are the Black Gate NX-Q type, the very top of the range which are said to sound best. (Unfortunately they do not do them in the 4.7uF value)
For input resistor, I like the sound of the carbon film that I am using. I think that it is a good idea to mix-and-match resistors to prevent one type from having too much affect on the sonic signature.
If you have been to my FAQ page you probably know that there is a link to my full GC shopping list. :nod: |
| tiroth |
Supply caps: Panasonic FC
Resistors: Dale
Coupling cap: ? |
| glyphin |
Panasonic FC's sounded pretty good but the amp didn't reach the rhapsodic level we read about until I bypassed them with 1 uF Auricaps (metallized polypropylene). Without the bypass it was a bit grainy and harsh. Cheaper film&foil bypass caps would probably work too.
I'd like to know how a non-bypassed Black Gate sounds in comparison to a Panasonic FC bypassed with a good polyprop. |
| GrahamnDodder |
Thanks for the responses so far!
About the Auricaps bypassing the 100 uf FC's. I am assuming they just go across in parallel with the 1,000's? Am I right?
Also, are metalized polyprops directional like electrolytics?
TIA,
GnD |
| millwood |
I have tried the following in my set up (current two channel but eventually a 4-channel setup):
feedback resistors: Radio Shack (5% carbon), and Panasonic ECG (1% metal).
coupling cap: none, aerovox, and BC Components.
by-passing cap: none, Radio Shack, and Panasonic ECG (metalized polypropylene).
I hear no difference. |
| GrahamnDodder |
Millwood-
You say no difference. But how do you like your amp's sound on a scale of 1 to 10? Are you running decent components around it?
To me, this is very good info.
People spend a lot of time splitting hairs over the relative benefits of an array of very expensive parts here. Much of this is "last 5% returns" area. IMO, what is equally important is a discussion of the meat of the curve, so to speak.
I am a big proponent of getting 90% of the quality for 40% of the sound, for example, when possible. That is what partially attracted me to DIY. I expect others here feel the same way.
Don't get me wrong. I value very highly the info of those people who are squeezing the last ounce of performance out of their GC's. As a professional photographer, I feel that way about my lenses and cameras. Leicas are a photographer's Black Gates, so to speak!
Anyone have any input on carbon vs metal film in the resistor arena? Some guys are "leg men". I am into smooth midrange. I have a hunch, with nothing behind it whatsoever, that carbon might help in this area. Any experience, anyone?
I said earlier that I am looking for the Camry of Gainclones for my first one out of the block, which, admittedly, might not be the final amp component of the project. But hey, there's a reason a lot of people drive Camry's, huh? And I do, BTW.
I like the idea of Panasonic 1000uf FC's with a good small cap in parallel. Am very interested to hear other's experiences of where to get a lotta-bang-for-a-little-extra-buck, too.
Unfortunately (or fortunately, perhaps) I don't have a bench full of spare parts lying around. So, while I won't build it as cheaply as possible, I won't be forced into a bad component just because it is there, either. |
| glyphin |
The Auricaps have a red lead and a black lead, so I wired them parallel in the same orientation as the Panasonics. They're equally close to the chip on one side (~1 inch) and have a separate ground wire connecting to the star ground.
I wouldn't say the bypass was a matter of last 5%. To me it was the matter of being "good solid state" versus "superlative"; a jump between the $1000 level and the $3000+ level. I'd rate it a 20% improvement in sonics. It only doubled the cost of PSU caps (the Panasonic 1000uF were $6/ea and the 1uF Auricaps were $7/ea).
I appreciate midrange too - my DIY speakers are arrays of fullrange drivers, lacking real bass and highs but very coherent in the midrange. I used metal film resistors. The GC on a friend's truly full range multiway speakers sounded slightly bright and forward relative to his Plinius, but this was before I did the cap bypass, and when I had undersized input caps. Now I might not be able to compare because I left out the input caps entirely - he won't trust the amp to not blow out his tweeters. In any case on my speakers it sounds very clean, accurate, and enjoyable, but definitely not warm and rich like a good SET or even like the Plinius or my MOSFET Belles 150a. |
| millwood |
| quote: | Originally posted by GrahamnDodder
Millwood-
it certain sounds good, but nothing spectacular. I have at home a Parasound amp, a Sony AVR and a good old Kenwood stereo. The gainclone does not sound as clear as the others at high volume but at low volume, it is indistinguishable.
The parasound gives the clearest sound under load, followed by the Kenwood and the Sony doesn't have the "punch" of either of them. The gainclone, however, offers as much punch as the Parasound or the Kenwood, but at lower volume.
I would think most people will be happy with Radio Shack based Gainclone and you can always replace the RS parts with better ones if that makes you happy. |
| Peter Daniel |
| quote: | Originally posted by glyphin
Now I might not be able to compare because I left out the input caps entirely - he won't trust the amp to not blow out his tweeters. |
You will not blow the tweeters, as there is usually a coupling cap in a crossover with a tweeter. If anything blows it's usually bass driver as it doesn't have high pass filter.
I once blew both midbass units ($500 value), but the tweeter didn't suffer at all, when 40V DC hit the speaker. |
| GrahamnDodder |
Oops.
Just saw my post #6. I meant 1000uf's where I said 100uf's. Hope my stupidity was obvious enuf.
GnD |
| glyphin |
Millwood -
What speakers is your Radio Shack GC driving? The consensus seems to be the GC works best with efficient, high impedence speakers. Your observation that it sounds better at low volumes suggests your speakers aren't efficient enough. Parasound is designed for home theater so despite their lack of refinement they can at least drive tough loads.
Peter -
What caused DC to hit your speaker? I measured negligible DC offset from my DAC, so I'm just operating on faith that nothing disasterous is going to occur. *fingers crossed* |
| Peter Daniel |
It was a faulty operation of my A75 amp, it wasn't GC.
I'm not really sure what exactly happen with the amp, but I had to replace one mosfet. |
| millwood |
Millwood -
What speakers is your Radio Shack GC driving? The consensus seems to be the GC works best with efficient, high impedence speakers. |
I tried a pair of PSB alpha, and then some H/K computer speakers. Same thing. |
| fmak |
BG FKs are much better, Ns are fine too, as are Nihicon KZs.
Haven't found them to be magical , as some say
Welwyn RC55s are magnetic, they seem to sound ok but I prefer to avoid them. Dale RN 55Cs are better. |
| Nuuk |
| quote: | | Welwyn RC55s are magnetic, they seem to sound ok but I prefer to avoid them. Dale RN 55Cs are better. |
fmak, where do you get the Gales from?
The NX-Qs need a very long time to sound their best but when they do, it is worth the wait. I was 'lucky' to have had some for my GCs that had already seen service in another amp. |
| analog_sa |
| quote: | | it certain sounds good, but nothing spectacular. I have at home a Parasound amp, a Sony AVR and a good old Kenwood stereo. The gainclone does not sound as clear as the others at high volume but at low volume, it is indistinguishable |
Use supermarket parts and you get supermarket sound. I bet even the Parasound is using better components.
Capacitors
I have terminally given bypassing - it always sounds disjointed to my ears. Rather live with less bandwidth than unnatural sound. That said, i certainly haven't tried all bypassing combinations. Much easier to simply use std BG.
Carbons
The Rikens are probably the best value. Rich, smooth and powerful midrange. Deep bass. A bit of old-fashioned coloration in the mid. Can i live with them? Probably, but not using them to excess. You would certainly not call them fast.
cheers
peter |
| Nuuk |
Having been unwaged for 16 years, I certainly have to work to tight budgets but in the case of the GC, I wonder just what is the difference between buying the cheapest parts and something that will give a much better result.
In the case of resistors, for people that don't have any parts to start off with, they will probably find that they have to buy minimum order quantities of standard items like carbon/metal film types. The total cost could even be a little more than buying just two resistors like the RC55s.
You could certainly spend a lot more on capaictors but for the GC we are only talking about three (that matter). Leaving out the very expensive types like Black Gates, a decent item will not cost very much more than the very cheapest.
So while I appreciate that people must work to a budget, and while I also understand the law of diminishing returns, I would say to GC builders, don't agonise too long over buying the better components recommended on these forums.
The difference in cost is nowhere near the value of your time in upgrading components after you have built a GC. :nod: |
| analog_sa |
Well said Nuuk
Over the years i have accumulated boxes of parts, sometimes 'audio grade' which are pure junk and i'll never use. No amount of opinion polling will really help you decide what sounds best for your ears. Sooner or later you have to bite the bullet and listen for yourself if you're half serious. And be ready for the occassional disappontment :) |
| millwood |
| quote: | Originally posted by analog_sa
Hm, if I invest in a company with designer cash, should I expect higher returns?
the amp behaves the same with RS parts, no parts, and some better ones (BC, Panasonic and aerovox), to remind you. |
| Nuuk |
| Just a timely reminder that parts quality is only one aspect of the over all sound quality. Circuit design and circuit construction play a huge part too! |
| fmak |
[QUOTE]Originally posted by Nuuk
[B]
Farnell - you need the Newark part no first from the net. I tend to be suspicious about every long burn in. I suspect that one gets used to the sound. Good components should sound good after say, a week or so. Maturation should lead to improvement. |
| miguel2 |
Where can we buy Blackgates in Europe? RS and Farnell dont seem to sell them. What about Elnas RJH?
What resistors are you using for the output 0R22? I saw Caddocks in the RS catalog for 4.93 euros which seems a good choice.
I have a supermarket GC based on OPA549 and now I want to try the real design :)
Miguel |
| analog_sa |
| quote: | | the amp behaves the same with RS parts, no parts, and some better ones |
I was also beginning to suspect that yor amp behaves the same with no parts. Thanks for the clarification. |
| Nuuk |
| quote: | | Farnell - you need the Newark part no first from the net. |
So they are not in the Farnell catalogue then? :confused: |
| millwood |
PSB Alpha's are a ported bass two-way design so they have a impedence dip to around 4 ohms at the port frequency. |
that made a lot of sense: the psbs forced a pioneer 45tx to shut down under reasonable volume. and that avr had a known shutdown problem with <6ohm speakers. |
| millwood |
I am glade that you finally GOT it, :). |
| Peter Daniel |
| quote: | Originally posted by fmak
Without burning in period, I found standard BG to sound better than N type. Even now, after quite a long time of usage, I'm still not sure if N types are much better than 3 times cheaper standard grade of BG. I never tried FK, could it be that they are better than N type. It seems to me like standard caps present more direct and lively sound, while N type is very laid back with possibly more detail.
Capacitors
I was bypassing before, as this was a common practice I picked up without much thinking about it. My recent experiments show, that indeed when bypassing the sound the sound seems to be indeed disjointed. You got initially the impression of more clarity and detail, but this is at the cost of loosing natuaral integrity of the sound, if I can use that expression.
As to resistors, while I like the Caddocks in feedback position over Rikens, I recently tried Caddocks as I/V resistors in my tda1543 DAC and I preffered Rikens. So I would say that choosing best resistor for a job is very circuit depandant, you just have to try as many as you can and choose the one you like the most.;)
Mills wirewounds (5W) work pretty good at the output of GC with adding only a little bit of sonic signature, which is not annoying. If you looking for that resistors, put an add "parts wanted" in trading post as those resistors were bought in 1K quantity as a forum's group buy. But you don't really need those resistors. |
| carlosfm |
Guys, just some thoughts here.
It seams many people like Panasonic caps.
Experience tells me, from devices I own or owned or devices from other people I've put my hands on, that they don't last long.
In reliability terms, they are the worst I've seem.
After having plenty of problems with my Panasonic video over the years, which I always fixed by my own, and a Technics cassette deck, and lately a CD player that was given to me, I have to say this:
I AVOID PANASONIC CAPS LIKE THE PLAGUE!!!:devily: :bawling:
Deam, on that CD player there were about 20 1uf caps, all Panasonic, and all with moisture under them.
The Elnas were perfect, and the cheap ones too.
It's always the same story, believe me.
Now... I don't use high-end caps, even on my GCs.
When I buy caps I look for Philips, Rubycon, Nichicon, Jamicon, etc.
I used 1000uf Daewoo:devily: caps (I had them...), bypassed with Philips 6.8uf, and again 0.1uf poly on my GC. The input caps are Philips 2.7uf polyesters.
The sound is so impressive...
Actually, I think that more important than using cap A or B is the layout.
You can eventually hear a small difference from one cap to the other, but with a bad layout even the BGs won't save you. |
| fmak |
| quote: | Originally posted by Nuuk
So they are not in the Farnell catalogue then? :confused: ---------------------------------------------------------------------
Farnell owns or have ties with Newark
----------------------------------------------------------[QUOTE]Originally posted by Peter Daniel
[B]
You should try FKs; they sound good with short burn in. I don't like the standrd BGs for coupling much.
| Peter Daniel |
>>You should try FKs; they sound good with short burn in. I don't like the standrd BGs for coupling much.<<
For coupling I'm only using N type and its always 4.7u (as that the value I only keep). With standard grade (and N type) I was talking about 1000u PS filtering caps.
I don't know about Panasonic cap. Maybe the specific type you saw wasn't good. I'm using whole bunch of HFQ 1,500u in one of my amps, I checked the recently after 8 years and they measure pretty good. The temp in the amp is about 50deg C. |
| carlosfm |
| quote: | Originally posted by Peter Daniel
They may be good caps, but they don't last lonng, believe me.
When I see one, I replace it.
Not a specific type.
I've seem plenty of them.
I replaced ONLY all the Panasonic caps on that CD player and the transport came alive.
Before it didn't read one single CD.
Not to tell you the story of my video (all the electrolythics replaced) and my cassette deck (same story).
Oh, and I had to open my TV a year ago.
There was a bad cap there.
Panasonic.:devily:
I just gave you my experience.
I avoid them like the plague. |
| fmak |
HFQs are popular in N America. However, they are no match for Nihicon ZL and ZAs for low impedance. Try them, even though they cost more. |
| Peter Daniel |
| I didn't even see Nichicon ZL and ZAs in here. Just KZ, FA, FG, FX, FS and ES. |
| pmkap |
Fmak -
I believe the ZAs and ZLs you are referring to are Rubycon capacitors. If anyone knows where one can buy these Rubycons in small quanties in the States (or anywhere else), I'd appreciate it. Pioneer Electronics used to have the 50v, ZLs 1,000 mmf, but they've been sold to Avnet.... |
| fmak |
I believe the ZAs and ZLs you are referring to are Rubycon capacitors. If anyone knows where one can buy these Rubycons in small quanties in the States (or anywhere else), I'd appreciate it. Pioneer Electronics used to have the 50v, ZLs 1,000 mmf, but they've been sold to Avnet.... [/B][/QUOTE]-------------------------------------------------
Sorry, slip of memory - Rubycon available from Farnell or thru' Newark perhaps since the two are linked. |
| fdegrove |
| quote: | | I was bypassing before, as this was a common practice I picked up without much thinking about it. My recent experiments show, that indeed when bypassing the sound the sound seems to be indeed disjointed. You got initially the impression of more clarity and detail, but this is at the cost of loosing natuaral integrity of the sound, if I can use that expression. |
My theory on this is that it's probably the difference in transient response from the two different technologies that is responsible for the subjective feeling that the sound is disjointed.
It's anologous to trying to mate a fast mid-high ESL panel to a dynamic woofer...when done wrong you have a similar impression.
Simpler still, if you use a filmcap in the tweeter section of a two way LS and a lytic in the low-mid section it also seems as if the tweeter is out of character with respect of the rest of the frequency range.
With modern good quality, low ESR lytic caps available it doesn't make all that much sense to decouple anyway.
Another analogy where the same subjective effect occurs is when you transit from say, solid core wire, to multistrand, at least IME.
Cheers,;) |
| millwood |
| quote: | Originally posted by carlosfm
I am just the opposite. I have had multiple Sony failing on me, but my Panasonic have held up reasonably well. The only Panasonic failed so far is a shortwave radio where the battery connection for somereason went south. |
| carlosfm |
| quote: | Originally posted by millwood
I was talking about Panasonic caps.
Their gear usually has plenty of them, but sometimes not so many.
The CD player I was talking about is a Telefunken.:devily:
My TV is Philips, and had a bad Panasonic cap.:dodgy: |
| Sawzall |
| Drop me an email about hooking up a Digital out (S/PDIF or AES) for the XM units if you have not seen the hack yet. Significant improvement in sound. |
| miguel2 |
Hi Peter,
You dont use the 0R22 resistors on the output?
Miguel |
| Peter Daniel |
| quote: | Originally posted by miguel2
Hi Peter,
Miguel |
No,
I tried them but didn't hear any improvement, but the sonic signature of the resistor. My amps were tried in many different systems and so far, I didn't experience any problems because of lack of that resistor at the output. |
| GrahamnDodder |
This is probably old news to the more experienced builders here, but I just got the catalog of "Parts Express" (website here: http://www.partsexpress.com/ ) and it is much more help than the typical Mouser/Digikey catalog. Their printed catalog is free. Mine arrived in about 10 days. Definitely worth getting.
They have a ton of audio DIY stuff - hundreds of different drivers, real "ports" for less than a buck, and other stuff. And their descriptions of the qualities of the different caps and resistors they sell was most helpful.
As soon as my chips come in (can't remember whether I ordered the ones that need silpads or not) I will place a Mouser and Parts Express order for the rest of my amp components!
GND |
