diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
DC sensitivity of toroid transformers? - Click HERE for Original Thread
tubetvr
Hi
As some of you may know there are sometimes a risk to get a lot of mechanical hum from toroid transformers due to a DC component on the mains voltage.
I have read somwhere that Jeff Rowland in his amplifiers use a circuit consisting of diodes and capacitors between mains and transformer in order to remove the DC component.
Has anyone any information on how this circuit look like? I can imagine that you can build it using 2 Zener diode connected in series but I wonder if anyone have any idea how it is done in Jeff Rowland amplifiers?
Regards Hans
theChris
likely the answer can be found in the pages of:
http://www.diyaudio.com/forums/show...=singing+toroid
Page generated in 0.016860008239746 seconds with 17 queries,
spending 0.00764298 doing MySQL queries and 0.00921702 doing PHP things.
Please support our sponsor.
