diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
1:2,8 f108 good lense? - Click HERE for Original Thread
moi
can i use this lens (from a slide projector)
1:2,8 f108
thanks
mhelin
That's good for small LCD's (less than 5") only. I think good focal length fo any LCD is the screen size (so for 15" monitor panel 15" FL is ok). Remember that you also need a fresnel with the same focal length (or just a little bit more) as the projection lens have to get bright picture. You can also use two fresnels to shorten the FL. In your case with the slide projector lens you could use dual side (OHP) 10" FL fresnel between the light source and the LCD and single 10" between the LCD and the projection lens.
moi
thanx
i'll try it tonight
bye
Page generated in 0.029282093048096 seconds with 16 queries,
spending 0.01934147 doing MySQL queries and 0.00994062 doing PHP things.
Copyright ©1999-2009 diyAudio.com
