| Lower supply rails for this amp? - Click HERE for Original Thread |
| Christer |
Shouldn't be any problem as far as I can see, but the maximum
output power will be lower, of course. A rough calculation would
be around 55W in 8 Ohms.
Maybe one should lower the value of R3 correspondingly, but
that is probably not necessary. |
| mik |
Thanks Christer!
I think that 55W in 8 ohms are enough ! |
| djk |
Change R3 to 39K
Because of the lateral MOS this amplifier will only do about 40W at 8 ohms with a simple ±40V supply.
The Hafler DH120, SE120 use about the same circuit and ±52V and do 60W/8R or 90W/4R(1Khz)
http://www.hafler.com/techsupport/index.asp?ID=3 |
| mik |
DJK
Thanks for your suggestions! |
