diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
can I place a port? - Click HERE for Original Thread
Tony.ca
Hi there guys,
Just wanted to know if I can mount a port directly behind the driver or should it be placed on the same side where the driver is mounted.The problem I have is I don't have enough space on top of the box the sides and the front to mount a 4" dia port,I am using it in a car so The only option is to have it behind the driver.
Is it possible to mount it at the rear?
Any suggestions please
Thanx,
Tony:scratch:
iaudio
What are the dimesions of the enclosure and what speaker are you using?
Ideally you would want the port to be on the same side as the driver but you can get away with having it on the top or sides.
Page generated in 0.062603950500488 seconds with 16 queries,
spending 0.05285192 doing MySQL queries and 0.00975204 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
