diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Building: Need Help - Click HERE for Original Thread
ICARE
I need HELP for builing a nice stereo tube amp: Really good quality but not really expensive, around 1000 dolars
Can you give me links, realisation, price, etc....etc.....for building it.
Iīm looking for something not too difficult to realize with a really good sound and nice looking.
Thanks in advance.
BUILDING: NEED HELP
Joel
$1,000 is a lot of money.
EC8010
$1000 is a lot of money if you have a basic engineering knowledge and are able to salvage electronic components and can make your own chassis, but just need a little guidance on how to best do it.
On the other hand, if you mean, "Which is the best kit for $1000," then it won't buy you quite as much.
Do you have religious principles about single-ended vs push-pull? Are you happy to bu a second-hand amplifier and modify it? Does it have to look so good that photographs of it could be published in magazines that have to be kept on the top shelf? How much power? Does it need a pre-amplifier, or will a power amplifier with volume control and selector switch do?
fdegrove
Joel, may I please ask you to refrain from commenting on monetary aspects?
From where I stand it's just none of our/your business how much a person is willing to spend on a project...
If you feel it's too much than at least propose an alternative path that coincides with what the threadstarter has in mind.
In Europe, and I'm sure as in other parts of the world it is as well, we often want a quality of finish that has not only a high WAF factor but fulfills all of our audio needs as well.
In other words we look at music as art not just as an object.
No offense at your personal work, just something to keep in mind.
Thank you,;)
NickC
if you want you could try building a pp amp. BUt se is much easy to deal with. I built 5 amps so far 2 were pp 1 was se 2 were pre. I can easily say se is easier for the begineer just the power factor
i design and built my own pp el34 you can have a look at www.geocities.com/nickchua81
but it involves alot of parts to make it work
most of the supplies are regulated from driver, heater to negative voltage bias. Good thing is the drivers are direct coupled to the output tube.
I think you should check out angela website. I seen a se el34. which is simple and easy to built plus part are not that expensive. El34 cause around 28 dollars per match pair compared to higher for other tubes.
For a kit check out diyhifisupply i think, they stock their billies(300b se) and ella amp (el34 pp). Billies is slighty expansive due to 300b but the ella amp is around 526 dollars without tubes plus el34 and 6sn7 tubes are cheap. Billie is around 800 dollars without tubes. Tubes cause a bomb. 300b especially, 5u4g and 6sl7 .
ShiFtY
I have found single ended triodes with a good output transformer sound fantastic. You might want to look at a 300B kitset, 8W per channel of pure triode power. This doesn't sound like much, but it is. Single ended triode amps are probably the nicest sounding amps you can get. (me waits for flames:) )
You can build a great sounding amp for $1000, thats for sure. Lots of options.
Brett
quote:
I'm glad you think so but it's far from a universal truth. There are many extraordinary PP designs out there that can equal or better a SET in the mids, have much better top and bottom, lower distortion (esp IM), less reactivity to load etc, and are to my ears (if not everyones) far more musically enjoyable than any SET I've ever heard. Most people's experience with PP revolves around bad Williamson or Mullard circuits, which is only a subset of possible designs. It's also easier to find better used OPTs for the same money as a lot of new SET designs which adds some options. As does the usually double power that a PP will give for a similar implementation, which is a big advantage fror those with less efficient speakers.
No flame, merely different opinion.
Yes, and better suggestions can be made with the answers to EC's questions above, as well as,
- how efficient are your speaks?
- how loud do you play?
- what's your level of skill in electronics?
- what type of music do you listen to most?
Cheers
316a
I'm with Brett , SE triode topologies are not always the best . It may be advisable to go with something that suits the available speakers . Bass reflex speakers for example don't seem to work very well with zero feedback SE amps . SE 2A3 amps require sensitive speakers and so on . Push pull designs on the other hand can provide more power and better driving capabilities for the price . Consider the amp and speakers as a system on their own... get my drift ?
316a
dhaen
People are attracted to SET for the simplicity of the circuitry.
This makes it more approachable, though not normally cheaper.
Morse
Hi 316a;
>>>...Bass reflex speakers for example don't seem to work very well with zero feedback SE amps . SE 2A3 amps require sensitive speakers and so on...<<<
Please take no offence, but IMHO it's really an overgeneralisation to say that zero NFB SET's don't work well with BR speakers. I'm using Fostex 164's in BR alignment cabs with my 2A3 SET; I've also successfully used Radio Shack 40-1354's in BR cabs and a pair of ancient EPI 100's with that same 4 watt amp.
IMHO the things that determine whether or not a set of speakers will work well with a low powered SET are the crossover (less is better and no crossover at all is the very best) and the efficiency - 89dB SPL for moderate SPL's in a small room and about 94+SPL for higher volumes in larger quarters. Fullrange speakers with 89+dB SPL really do seem okay with low powered SET's in my personal experience at moderate levels. SOME 2 way speakers with a single cap on the tweeter are okay if a little limited in dynamics.
Anyway, you're very right that it's best to match the topology of amp to the speakers. Moderate to high efficiency combined with a simple crossover is the key to making the flea amp perform it's best.
All the best,
Morse
316a
...alright then ! Hope this sounds better '...Bass reflex speakers >>to me<<:2c: for example don't seem to work very well with zero feedback SE amps .' Owzat then ? YMMV and all that abreviated IMHO **** etc . Do you think we could have a 'YMMV/IMHO/WTF/LOL' and so on free day with a day in the sinbin for active perpetrators ?
316a
karma
http://www.tubecad.com/index.html
wow $1000 your going to have fun. but there right you can make em cheaper. i have picked up a few from e-bay that had to be restored. when finished thay sound great. $100 dolller wonder's
turn out good. new tubes are cheap. at least i think thay are.
or you get the meathead that kills his iron and post it on e-bay as is
never had that problem yet;)
Morse
Please accept my apologies 316a. I didn't mean to press any buttons, just to help ICARE.
ICARE, you could take a look at http://tinpan.fortunecity.com/saint...imer/index.html
for inspiration. There are quite a few good ideas there. Also, there's http://www.triodeel.com/schindex.htm where you can find the schematics for quite a few interesting little projects.
For $1000USD you can build some serious audio firepower - but if it's your first 'from scratch' project you might consider something a little less ambitious first, depending on your skills with a soldering iron, etc. There are some really good projects to be found at http://headwize2.powerpill.org/projects/index.htm
I've built the Morgan Jones headphone amp that's to be found there and it's a good sounding little project. You should be able to build one for something like $100 (maybe less if you're a skilled scrounger), depending on the local cost of components. If you're a complete novice to the soldering iron you could try a Chu Moy opamp based headphone amp as a first project - that can be built for maybe $35USD and is a good 'very first' project; the worst that will happen if it's a total disaster is that you're out $35.
All the best,
Morse
Joel
quote:
Originally posted by fdegrove
Joel, may I please ask you to refrain from commenting on monetary aspects?...
No, you may not. The original poster is the one who introduced a budget of $1,000 - not me.
cheers
Joel
ICARE
Thanks for all the information.
When I said 1000 dolars, it was a top. I prefer spend around 600 everything include. But I prefer spend a bit more and have a really good sound.
So if someone can give me more ideas and informations, let me know.
Thanks in advance
fdegrove
If you prefer to build from a kit, you may want to take a look here:
WAD
Cheers,;)
ICARE
Thanks, you have really nice ampl...
I donīt know if prices are good, but they have good choices.
bye
Bas Horneman
Hola ICARE,
Brett said:
I suppose he is right...that said the only PP i would want to build would be where a transformer is used as a phase splitter. So now you are looking at $$$. I have been pricing the Petit Amity a design published by Lynn Olson http://nutshellhifi.com ...comes to about $1600 (That is for the major parts like tubes, sockets, transformers, no nuts and bolts / switches / chassis)
Whereas a 300b SET based design (DRD) would set you back..say $800.
Bas
ICARE
I need one more think, how do you called in english the "thing" who control the quality of tubes:
--valves meter ?
--tubes meter ?
etc...etc...
I want a buid one, but I donīt know how you call it...
Or maybe you can give me plans, direction, e.mail etc...etc... for make one
thanks
dhaen
quote:
--valves meter ?
--tubes meter ?
etc...etc...
thanks
Duplication. Jump to this thread.
This thread..
Page generated in 0.083265066146851 seconds with 17 queries,
spending 0.03452063 doing MySQL queries and 0.04874444 doing PHP things.
Copyright Đ1999-2009 diyAudio.com
Please support our sponsor.
