diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
rectifier tube 5u4g - Click HERE for Original Thread
karma
i have started a new pre amp and was wondering if i could just
use this rectifier tube i have no small ones left. im sure i can just wondering if anyone used bigger rectifier tube on a small pre;)
Magnetmaz
I love the big bottle 5U4's. There's no reason why you SHOULDN't use it :)
-Maz
fdegrove
Can do, but IMHO you best feed it for a highish voltage and reduce it from there...a lot of voltage gets wasted that way, generating a lot of waste heat in the process.
To be perfectly honest with you I haven't tried a 5U4 at low voltage but it sounds off to me...
A few damper diodes would do nicely though and they're still cheap as mudd.
Cheers,;)
Colt45
its fine, if you dont mind wasting power..
karma
good ill use it i love to wast power lol;)
Joel
5U4 has a 3 amp heater - make sure your PSU is up to the task.
I'm not sure what power everyone thinks he will be wasting though - the voltage drop over a 5U4 is significantly less than over a 5Y3 for example. How much voltage does the circuit need?
Ken Chuang
I am actually thinking of using a 5U4 rectifier for a 6SN7 separate PSU preamp design soon.
The advantage of this approach is that you can actually adjust the voltage using resistors in the separate PSU and build a new preamp at half the cost if you get tired of listening to it. You have to select a mains transformer with 12.6V tappings which you can convert to 6.3V readily.
This is however a non-purist model, usually have to work backwards to calculate power requirements and use small values of resistors as possible and appropiate rectifier tube.
Some others also say the 5U4 is way over kill. Yes it seems like running an aircraft engine on a small motor cycle. But that's what DIY people often do. Getting all those military stuffs, Black Gates, Kiwames, oversized mains and output transformers, hospital grade power plugs etc.
It's not for everyone, but no harm trying with a Sovtek and see if you like the end result. It's good to have a open mind for these things. You never know.
fdegrove
That 3A heater is what I meant, Joel.
Considering it's probably for a linestage pre it seems overkill, don't you think?
Cheers,;)
JojoD818
I need to use a 5U4G for a friend's preamp. The preamp needs a B+ of 330VDC. I downloaded the datasheet of 5U4G and looked at the pinout but can't figure out how to wire it. I was told this is a "Flaming Valve" and the output voltage is taken from the filaments?
Can anyone please give me a circuit that shows the wiring of this diode? I am so confused with this filament output scheme and I don't want to blow-up my friend's 5U4G.
Thanks!
JojoD
fdegrove
This is a typical circuit using a cap input supply:
Cheers,;)
JojoD818
quote:
Cheers,;)
Thanks a lot Frank! I knew you'd rescue me! ;)
Cheers!
Page generated in 0.046350002288818 seconds with 17 queries,
spending 0.00998068 doing MySQL queries and 0.03636932 doing PHP things.
Copyright ©1999-2009 diyAudio.com
