diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Regulator IC Data - LAS19U - Click HERE for Original Thread
JDeV
Can anybody help me with data on this IC:
It is a LAS19U , type of adjustable voltage regulator I think. (From Lambda??)
Is in a TO-3 package with 4 legs.
I want to use it for such a purpose, if possible, but will need some data on the pin-outs and voltage + current specs.
Thanx
Netlist
LAS19U: +4..+30V, 5A, 50W(Tc=90), -55..+135
LAS19U = UA78HGKC
The Lambda company is no more, but the LAS19U has been manufactured by Unitrode corporation as well, which is now a part of Texas Instruments.
On the TI website however, there is no findable data on LAS19U.
Also no data for the UA78HGCK.
/Hugo - the best he could find..;)
JDeV
quote:
LAS19U = UA78HGKC
Thanx for the info.
Are there any safe way of determining which pin does what?
Netlist
What I would try is the following:
Apply VERY little current and voltage (4V) with regulated PSU to different pins. Measure the other pins behaviour. Keep an eye on the ampere meter. Case will be ground or output.
I know this is not the conventional way to go, but I only tell you how I would try. Other people will be able to tell you which ohmic values you can expect between different pins.
/Hugo
JDeV
What could be a possible use for the 4th pin?
Normally you got a: (LM338 for example)
1)Adjust
2)Vin
3)Vout - case
or similiar alocations.
Netlist
No idea, but take a look at this:
http://www.cygnal.co.kr/KA78R33.pdf
/Hugo
moamps
maybe this unfocused picture can help.;)
Netlist
quote:
Well, there you go JDeV, forget post #4 ;)
/Hugo - moamps rules!!
JDeV
Thanx for all other info supplied.
For others who might need it someday:
Here is the origenal datasheets.
File 1 of 2:
JDeV
File 2 of 2:
Page generated in 0.037144899368286 seconds with 17 queries,
spending 0.00765347 doing MySQL queries and 0.02949142 doing PHP things.
Copyright ©1999-2009 diyAudio.com
