diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
aleph 60 - Click HERE for Original Thread
janey
hello
l would like to build a aleph 60 but with some modification:
these are:
power supply rail 25V - 30V
output devices IRF540
do I need any other modificaton on the circuit?
thanks
janey
Freddie
Why don't you build an Aleph 30 instead? It uses +/-25V PSU.
/Freddie
Nelson Pass
Better yet, build a 60 output stage and crank
the bias up higher with the 25 volt rails.
janey
do i need any other modification.
is irf540 good for output devices.
what do you think about crank?
do you think aleph 30 (irf240) will sound better like aleph 60
on 25-30V (irf540) wich voltage is better 25V or 30V
thankd
Page generated in 0.015800952911377 seconds with 16 queries,
spending 0.00512695 doing MySQL queries and 0.01067400 doing PHP things.
Copyright ©1999-2009 diyAudio.com
