| Algar_emi |
Is anybody knows this tube preamp? Seem like a very good little preamp built around the 6922 tube. It is using quality parts ALPS pots, gold plated shorting RCA jack, WIMA caps.
And the price at 389U$ seems ok too.
Any other tube preamp not too expensive can be better?
Comments are welcome. |
| fdegrove |
Having followed your DAC posts I'd rather recommend something like the WAD pre or perhaps a Foreplay...
WAD
Nothing really wrong with the Velleman but expect to change the valves form the word go, they're pretty low Q.
Cheers,;) |
| Algar_emi |
What do you mean?
| quote: | | but expect to change the valves form the word go, they're pretty low Q |
I check the WAM and the circuitry seems rather simple to me. Is it a better desing because of the output transfo?
I would like to drive my Aleph30 with it. Will it do? I got 50K input impedance on the Aleph30.
Thanks... |
| fdegrove |
Don't read too much into it, it's just that I happen to know where they buy their valves.
Let's say that it wouldn't be too hard to find better quality jobs.
| quote: | | Is it a better desing because of the output transfo? |
It has its advantages in view of a CD based system.
| quote: | | I would like to drive my Aleph30 with it. Will it do? I got 50K input impedance on the Aleph30. |
Sure.
Cheers,;) |
| elizard |
http://www.qkits.com/serv/qkits/vel...pages/K8020.asp
$449 canadian .. about $100 cheaper than $389US :)
I don't know much about the 8020 kit, but I built the 8021 from Velleman.
Overall decent quality, although I did get cheap op-amps w/ the kit, so I swapped those out for some nicer ones. So I can only imagine that you won't get great quality tubes (as mentioned before), although I could be very wrong w/ that.
However, qkits has good tech support if anything goes wrong.
Also, as mentioned before (once again), the foreplay is a good alternative :) |
| Algar_emi |
Thanks for the tip, much cheaper indeed. Bye...
SB |
| choky |
| quote: | Originally posted by Algar_emi
"cheap" ****;
I have somewhere schmtc
better is to use any WOT based preamp,if ya need it to drive Pass amp.
tip-look for xformers from Vert. section of old BW tube TV sets,if ya need cheap solution for testing that concept.
:goodbad: |
| dhaen |
Choky,
In the west, we haven't used vertical output transformers in TV's for 38 years (32 years some Japanese imports).
Maybe some could be thrown over the wall ;) (ex wall).
And yes, I remember the ratio. It gave about 30 volts secondary, when 240 was on the primary.
Cheers, |
| choky |
| quote: | Originally posted by dhaen
Choky,
Cheers, | hehe-good one ;)
also,we (in the east) haven't used those xformers for few decades; but it's good to know old geezers ,with lotsa junk in backyards and attics
:nod: :devily: |
