diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
8" run in chassis before terminating SPDIF Signal... 75R Resistor Placement - Click HERE for Original Thread
PaulHilgeman
Should I leave the 75R resistor on the board, or is it better to move it right up to the RCA jack? and then run two strands back to the board?
-Paul Hilgeman
dhaen
Paul,
leave the 75 ohm as close to the driving device as possible. Then try to maintain the characterstic impedance (parallel, twisted, or screened from that point on.
Fred Dieckmann
WRONG! You have 8" of unterminated coax that will bounce reflections back. Since the RCA is also an impedance mismatch (now worse since it has 75 ohms in parallel with it) you will have reflections back in the other direction as well.
Keep the coax shield as close to the RCA jack ground as possible and terminate it at the end by the receiver. You terminate a transmission line at the end or beginning (back termination) preferably both. You don't terminate a line in the middle. Where do you guys come up with this stuff? I wish people would do some research and try to give helpful advice instead of guessing.
http://www.circuitsage.com/tline.html
http://www.mwoffice.com/products/txline.html
http://fermi.la.asu.edu/w9cf/tran/
jwb
Calm down smart guy. You ought to point out that both-ends termination will halve the signal level, which may cause a problem.
But of course you should run the coax as near to the receiving device as possible. dhaen's advice is just flat-out misinformation. Twisted-pair won't have the same impedance as coax, and it is unsheilded, so don't bother.
Didn't you forget <a href="http://www.sigcon.com/">your favorite link</a>?
dhaen
Mis-information?
Although not ideal, a twisted or parallel pair can have any impedance. Have you measured the impedance of a slow twist in some 7 strand hookup wire? It's not too far off - thank you very much.
Of course coax is the ideal. And who said anything about "unterminated"? Presumably when the cable gets connected the equipment at the other end will terminate the line. That's how transmission lines work - we have a source resistor in series with the source, and the same value across the end of the line - with cable of a suitable characteristic impedance inbetween!
So presumably you would put the resistor at the RCA?
What happens to the driving stage then? It has a cap slapped across it's output pin :clown:
Fred Dieckmann
quote:
Originally posted by dhaen
Mis-information?
I have not made myself clear I fear. If you put the resistance on the RCA jack you will have a unterminated 8" piece of line from the jack to the receiver. It will cause significant reflections. Good transports have 75 ohm output impedance to provide source termination many don't and use twisted pair wires to the jack or poorly terminated pulse transformers. The Crystal receivers don't like less than 0.5 volt signals but a competantly designed front end circuit for the DAC input can take less than half this. BTW if your input SPDIF circuit is within a couple of inches of input jack you can mount the resistor on the jack and use a pair ofwidely spaced untwisted wires to the receiver. Most twisted wires have about a 100 ohms characteristic impedance, this is a serious mismatch for 75 ohms. I can count the number of designers that do this interface right on one hand. I designed external digital interface devices for DACs for about three years. Doing this interface right gives big sonic returns.
The best book on transmission lines (yes, I have a copy):
Transmission Line Design Handbook (Artech House Microwave Library) by Brian C. Wadell
http://www.amazon.com/exec/obidos/t...=glance&s=books
davesaudio
whats the impedance of the RCA
I thought it was reasonably close?
PMiczek
The impedance of the RCA/phono connector was never 75 ohms, and assuming that 75-ohm BNC really _IS_ 75, the dielectric of the RCA connector looks nothing like it.
Better question would be, how is the typical 2-inch PCB trace 75-ohm, or a postage-size piece of ground plane that the coupling transformer sits on, or that hairpin shape trace in one of my old "digital-ready" components, etc...
...when that expensive interconnect cable makes contact with the chassis, I suspect you may as well kiss 75-ohm impedance good-bye.
Hisatugo
interesting discussion. I see many people talking the same thing by diferent ways. Since I do understand a small part of the electromagnetic theory, I also do my most confident audition about the electronics I have. What I can say is: even with all that traces, mismaches, terminations and etc.... there always exist something to do to get the equipment better. If you change something and you can really, honestly hear that change and it made the sound better, you are in the right way. If you can not hear the change, consider the undo possibility. Anyway, you can get wrong things or you can do work simply useless.
"There was a man that spent 20K us dollars to get a high end stereo system like his neighbor. But this man had a serious illness in the ears and a loss of 30dB SPL at right ear at 4Khz, 12 Khz and total loss above 14Khz both sides. But the pleasure of spent so much money conviced him that could hear details, ambience, etc... but in fact, he could not."
So, please guys, don't fight for nothing, the final statement for equipment in audio is music. Let's hear music, as real as it can be and not forget that.
Best regards to all.
Jocko Homo
I missed another rock throwing contest............darn.....
Anyway......no you do not want to run 8" of mystery wire from the connector to the PCB.
But if it is an RCA jack to start with, and no attention to detail has been paid further upstream..................
Yeah, it will work, and sound lousy. Passing data is one thing, getting it right requires careful attention to detail.
On both ends.
Of course, some people think that the Bose Wave Radio sounds good, so to each his own.
Jocko
PMiczek
So, if the connector is so important (and I would not dispute that for a second because I have seen the results of good and bad panel connectors in other types of transmission lines), the question remains, how can equipment manufacturers get away with long thin traces on one hand, and very odd ground connections on the other, between the S/PDIF transmitter and the connector on the back panel? Am I missing something, or wouldn't that screw up the signal worse than a couple extra inches of wire...
:scratch:
Jocko Homo
They can get away with it because "it works" and "it sounds great" are two very different things. (See rock throwing contest in the "Twisted pair" thread.)
The fact is, there are several explanations why they do this:
1.) They don't care.
2.) They don't know the difference.
3.) Whatever gets it through production as cheap as possible.
4.) SPDIF was never intended to be a high-performance interface, so why are all these silly audio nerds so upset.
5. ) Why not just use a TOSLINK, and stop complaining.
6.) Combination of above.
To get maximum performance out of this poorly thought out inteface, all reflections must be held to a minimum. I can elaborate later if you prefer.
Jocko
jwb
quote:
A long, thin trace on a PCB can be designed to have a certain characteristic impedance. By adjusting the width and thickness of the trace and the thickness and permitivity of the PCB material you can usually adjust the Z<sub>0</sub> in the range 50-100Ω. Not that I'm advocating long PCB runs over a properly placed coax entry point, but there's nothing illegitimate about a transmission line made from a printed microstrip rather than coax.
You could also say that your twisted pair can be adjusted to have the proper Z<sub>0</sub>, and you would be right. But any old piece of twisted pair you have laying around isn't going to do it. And the switch from coax to utp is still going to cause a reflection.
If you are going to do it yourself, and you have total control, why not go for the best solution: skip the panel connector altogether, put a pcb-mount coax connector right next to your receiver circuit on the board, and run the coax straight throught the chassis with a grommet. You won't easily be able to disconnect it, but it will work better.
PMiczek
Jocko,
From other posts I have read here, is it safe to assume that you do not suggest we should all stop worrying and learn to love toslink, or join some rarefied audiophile community with both money _and_ time to burn?
Because if you are, I could just spend an otherwise perfectly good. rainy, lake Mich. weekend listening to Bach instead of trying to improve a circuit that has all of about five parts to it (if you count the primary and secondary of a coupling transformer as separate parts, that is) :clown:
jwb,
quote:
If you are going to do it yourself, and you have total control, why not go for the best solution: skip the panel connector altogether, put a pcb-mount coax connector right next to your receiver circuit on the board, and run the coax straight through the chassis with a grommet. You won't easily be able to disconnect it, but it will work better.
I agree, but in this case there is no room on an existing board next to the transmitter. In the receiver, where I do have more control, I plan to put the connector as close to the receiver as practical.
Darn but you guys are fast off the mark...
PM
lineup
poor guy .. not hear music too well
he maybe better spend $20000 for some ear fixing
for that money he may even buy himself a pair of new ears
from some even more poor guy ;)
Page generated in 0.0502769947052 seconds with 17 queries,
spending 0.00492287 doing MySQL queries and 0.04535413 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
