diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Green VGA problem - Click HERE for Original Thread
sparkles
I have a litttle probel mwith my panel a davis transview. It works lovely in compasite mode and tv out from my computer but when i plug the vga socket in the colour goes funny with a hint of green streks anyone any ideas. could it be a driver prob or just a faulty panel and how can i get a good tv out pic if i carnt use vga
pizzi
Have you tried this? If you know the resolution of your panel you should adjust your computer to that same resolution before connecting it to the panel so it will sync correctly.
sparkles
i have tried that, i think it might be a fault with my panel as its a davis transview no one as any info on it. i have to run it though com video.
verbose mustafa
heh... is your vga cable broken?
Mario007
Yah it sounds like a loose wire inside the cable. Or maybe your panel has menu set wrong. Might also want to download powerstrip and play with all it's controls.
sparkles
i changed the cable and it still did it so not that, i dont know if it needs a special set up to work on the menu, i run it though the s video and its fine, does the picture improve if you run it though vga. I also get green streaks when i turn the brightness down on dark scenes is this normal.
sparkles
turned out to be a panel problem so no good, moved on to a lcd monitor now and the difference is amazing.
Page generated in 0.028347015380859 seconds with 16 queries,
spending 0.01538444 doing MySQL queries and 0.01296258 doing PHP things.
Copyright ©1999-2009 diyAudio.com
