diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
How to get a Video Input to TFT LCD PC Monitor? - Click HERE for Original Thread
makuk
I hope any guys or gals out there can help me by helping me answer "How to get a Video Input to TFT LCD PC Monitor?". All I need is a PAL video signal (RCA jack) to my TFT LCD PC monitor.. I want to plug any video input so I can i.e. watch TV using a VCR etc on it.
Hope u can help... Simple and cheap would be ideal.
Thanks!
ap0the0sis
you would need an adapter that goes from RCA-input to VGA out-put. Video converters do this. If you plan on using a PC as your media center then you can get a video-in card for your pc, then just connect the monitor to the PC.
ap0
Undream
Cheapest you'll be able to find is the $69 "Cheesebox"
http://www.avtoolbox.com/vd-660.htm
That'll do ya!
eebasist
Nahhh you can do much cheaper than 60....go to a video game store....and look for an xbox/gamecube to VGA converter....find the pin for video input and go right through there
mattboy2
could you elaborate on that a bit eebasist?. . .what kind of pircture quality would you get with that type of setup as opposed to a cheesebox or tv-3000? . . .specific models you could mention? Is this something you have done? as far as I understand xbox/gamecube video signals are never just one pin. Please correct me if im wrong.
lotus-eater
Anyone know where we can get the cheesebox a little cheaper.
Or maybe something similar to it.
I like the idea of that thing....
Undream
yeah. I always wanted one of the XGA Theater ones.
not only do you have your NTSC to XGA converter, but, also, a remote control and a cable tuner. That thing rocks. I'll probably buy one after I get a commercial projector.
linkified
eebasist
http://cgi.ebay.com/ws/eBayISAPI.dl...&category=41059
items similar to this will convert video to VGA
SVGA and XGA cost more
gui_999
I'll probably buy a viewsonic N5. 1024*768 output, remote etc..
lotus-eater
I would like a converter so that I can connect my lcd controller to the pci slot on it.
I think I can do this with the cheesebox, but I"m looking for something cheaper....
jwb
Check out the SIlicon Image iScan Ultra. Lots of video inputs, VGA and DVI outputs.
Or you can very easily build a component-video-to-VGA converter with an LM1881 (or similar parts from Zetex) and a handful of opamps. S-Video and composite wil be harder, but I'm sure someone makes an IC for it.
gui_999
Yeah, coponent to vga is easy with the lm1881, I have 5 of those chips here to build vga cable for xbox. The problem is that I have nothing that use coponent! Only composite or my PC. So to play my dvd I'll use my PC with powerdvd, but I'm looking for some schematics to build a converter for composite to vga. I don't know if building a line doubler will be complicated
gui_999
Can I buy something like this and build a convertion box?
http://www.futureshop.ca/catalog/pr...&WLBS=fs%2Dweb2
VHS and DVD, 480p..
I have some lm1881, I could build a convertion box. Will it work? And will everything works on my monitor. I mean, will the vhs, the cable and dvd works on componant to vga? or only the dvd??
usa_satriani
what about a TV card with an S-video or Composite input?
makuk
Hi All,
Thanks for all the replies.... just to give more info on my situation. I am using a Laptop so I am limited on the cheap solution for TV input etc... Ideally I would like to view the TFT screen standalone from my Laptop.
But on the other hand I wouldn't mind picking up TV on my laptop when travelling. So anyone know of a solution of a TV card/PCMCIA or USB which does not require external power?
Thanks again!
Andrew
usa_satriani
what about something like that :
http://www.hauppauge.com/html/products.htm#usb
gui_999
Ati tv wonder USB.. but the reviews aren't good
Page generated in 0.047820091247559 seconds with 17 queries,
spending 0.02099466 doing MySQL queries and 0.02682543 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
