diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Subwoofer Plate Amplifier Base Plate supplier? - Click HERE for Original Thread
jwells777
So I was thinking of putting together a DIY class D amplifier for a subwoofer with a few features that I imagine aren't typically found in your average amp. Probably something in the 1 to 2 kW range.
My primary interest is in the electronics/processing capabilities of the unit and not the plate portion. I was wondering if anyone knew of a supplier for buying just a standard base plate or would I be better off just buying the $99 dollar plate amp from PE and scrapping their amp section?
If nobody sells these standard chassis, does anyone know of a company that would do prototyping for such a chassis at a reasonable price in the 10 to 20 unit volume?
Thanks for any advice,
Jason
pinkmouse
Hi Jason
Before you actually buy some custom plates you should make up a prototype unit, as you need to define the number of pots, switches, heatsinks, etc. and their placement in your design. Using a pre configured plate may lead you to making compromises in layout.
I suspect that the Class D amp may also need to be completely encased in a grounded shield to avoid RF problems.
But, it sounds like a fun project, I hope you keep us up to date with your progress. Good luck!
Page generated in 0.014539003372192 seconds with 16 queries,
spending 0.00513029 doing MySQL queries and 0.00940871 doing PHP things.
Copyright ©1999-2009 diyAudio.com
