diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Loudspeakers
Recommendations for first speaker build - Click HERE for Original Thread
mcai7et2
I would like to build my own speakers, prefereably from a kit or from an established set of plans. Currently I am using Linn Index speakers which have fantastic midrange and are great with vocals but lose out under 100Hz. My next speakers should be fairly inexpensive (say, £100/$150 per speaker for the drivers) and ideally should fulfill the following criteria:
  • Stand mount (although they can be big)
  • Fairly efficient (will be used with a Naim Nait 3)
  • Capable of producing high levels of volume (:cool:)
  • Good with Rock/Dance type music
I realise a lot of these seem inompatible requirements, but I think the World Audio Designs KLS8 may work, this is a large bookshelf with a 10" woofer and horn loaded tweeter in a sealed 50L cabinet. It produces 42Hz bass and 94Db efficiency which seem to satisfy my requirements.
Is there anything else I should look at, and has anyone here built or heard the KLS8 and have any comments?
planet10
quote:
I'd think this would be an ideal situation to just add active woofers to your Indexes. Simplier than doing a multiway speaker as a 1st project, and the best thing you could do to improve the indexes. A pr of 8s per side with a plate amp (or a gain clone ) in each would do the job.
dave
navin
I second this. you cna get a pair of very nice 8" woofers for that price (Vifa M22 or Peerless CSX come to mind). I'd use a small Aleph amp though. the sub could double as a stand for the Linn. From what I know the Linn are not dance speakers.
Page generated in 0.030314922332764 seconds with 17 queries,
spending 0.01509452 doing MySQL queries and 0.01522040 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
