diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Ideas for regulated B+ supply? - Click HERE for Original Thread
ShiFtY
I am looking at adding some regulation to a power supply I am designing. Basically, I have a 425-0-425 tranny, and need 460 ~ 480VDC @ 200 - 220mA or so. The supply is for a stereo PP 807 output stage.
Unfortunately this rules out most tube rectifiers, I was going to use an 83 I have but it seems that a bit of the filament coating has flaked off (only glows blue in some places) :bawling: What a pity!
So it looks like solid state diodes will be used, possibly with a big old damper diode in series with the supply for a slow warm up. I have space for exactly ONE tube on the amp.
I have a 1.2H @ 450mA choke (15ohm) to use. The power tranny primary is also tapped, So I could boost the output by a little, maybe 10% without over-volting the filaments. (see PSUDE below)
I was looking at this schematic here : http://w3.one.net/~robgrow/circuits...supply/rps.html Obviously it would need a bit of beefing up, any recommendations?
I have done a little modelling in PSUD but the voltage is all over the place with a pi filter and a slightly varying load, esp with 5u4GB which is my other option.
Are there any better ways of going about this? Just brainstorming! Need ideas :D
Thanks in advance
Sch3mat1c
Your PS is exactly what I would build, given the materials. What, exactly, is wrong with it?
Tim
Page generated in 0.039160966873169 seconds with 17 queries,
spending 0.02751088 doing MySQL queries and 0.01165009 doing PHP things.
Copyright ©1999-2009 diyAudio.com
