diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Power Meter - Click HERE for Original Thread
PaulHilgeman
Has anyone looked at the power meter over at http://www.snippets.org/filters/wattmeter.htm ?
It looks interesting, and may be somewhat useful for testing stuff.
Thanks,
Paul
elizard
well looks simple enough to implement
for $5 you can get the chip from digikey (canadian that is!) and another $5 for led's ..
so $10 all in all to make it .. maybe i'll try it too! ;)
although i would love to find out if it works or not as well
gammelmalle
Testing ... what stuff? Seems good for RMS wattage but if not true RMS? I dont think it will be good for testing you wall outlet (how much your computer consumes) except for things with cos fi of 1 (that is resistive)
Please correct me if Im wrong!
But Ive used this IC for some of my projects and its OK.
björn
cocolino
Check this thread for info about (True) Audio-Power Meters:
http://www.diyvideo.com/forums/show...=&threadid=8723
JOE DIRT®
I have been using the LM 3914/15/16 for years.....it has a dot or bar functionthe 3915 is a log type and can fairly accuratenational has a great application guide on their website for different applications
Cheers!!The DIRT®
gammelmalle
DANKE
Thanks for the thread. I sure will read it
(Danke fur das ??? drath ? Ich will dass vierklish lesen) ????
björn
joensd
Hey Christoph,
I´ve just read you got this Elektor article about a wattmeter.
Would you mind sending it over?
I got a few Elektor articles as well so we could swap around.
TIA
Cheers
Jens
cocolino
Hi Björn,
you're welcome!
lessons in German;) :
Danke für das (den) ??? (don`t know an equivalent in German either... :cannotbe: ) . Ich werde das wirklich lesen.
quote:
Hey Christoph,
Jens,
no problem, just send me Your email adress.
As I have sent it to another member already it`s ready for "emailing".
The scans are rather big (even already downscaled in resolution) - can You receive 4MB without problems (but could send it in parts also)?
Page generated in 0.027836084365845 seconds with 17 queries,
spending 0.00686097 doing MySQL queries and 0.02097511 doing PHP things.
Copyright ©1999-2009 diyAudio.com
