diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Remote control units for panels: HELP! - Click HERE for Original Thread
flying_jumbo
Here's a problem that I wonder if anyone has had to solve.
I bought an ASK Campus 300 proj. panel from ebay, but there was no remote control with it. There are no 'on' panel controls, which means I can't adjust the picture properties or placement. Panel works fine when I run off a VGA input, but there's a problem with Composite video run through a Video to VGA converter. My video signal is in PAL, (I'm in Australia) and the picture position is out of whack. I need to control the vertical and horizontal position, which is impossible with no remote control unit. NTSC works fine, but nothing here uses NTSC except Laser discs.
Does anyone have the remote control unit for the ASK Campus 300 that I could buy?
Alternatively, there's a Palm Pilot app called Omni remote that lets you emulate an infra red remote control for any device so long as you can 'learn' the codes from the real remote, or if you have the IR codes to upload. I've got the Palm, but I still need the remote to learn the codes from, or the codes themselves.
Last resort is to buy either a TV tuner card for my ancient PC, or a PAL to NTSC digital converter, but I don't even know if that will do the job. The don't come cheap.
JOE DIRT®
I cant find ASK in my programming data base...is there another possible manufacturer???
flying_jumbo
I believe ASK was taken over by Infocus, because that's where I keep getting referred to when I look for ASK.
Unclebob
Same problem as you.
I have found this site:
http://ir.premisesystems.com/search.aspx?m=ASK
Which has the codes for the WSX. Looking on the www.ask.no site at the manuals the remotes look very similar. So could be worth the try.
The other option is call Ask in Norway. When I called I was given this response with these names and numbers...
Please call our office in Norway.
Let them know that you want to talk to some old Guru for these very, very
old panels.
Try Mr. Björn Berg or Mr. Thomas Kristiansen.
Number to our Norway office: +47 69 38 11 00
Good luck!
Page generated in 0.021100997924805 seconds with 17 queries,
spending 0.00720286 doing MySQL queries and 0.01389813 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
