diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Would optical connection reduce clipping? - Click HERE for Original Thread
poolguy
I get a lot of "clipping" when playing my MP3s. Its not audible but my clip indicator light comes on all the time. My connection is stero miniplug of my soundcard to left-right RCA on my receiver. I am thinking about getting a Digital I/O expansion card for my soundcard that has optical out. Would using optical connections reduce or eliminate the clipping or distortion I am getting?
grataku
Yes, in theory. How much is the i/o card going to cost? Doesn't your soundcard have a variable output?
François
I had the same problem on my computer. If you are using Winamp to play your MP3 files, you can adjust the preamp output level in the equalizer pane (right-click on Winamp and select Equalizer).
Of course, you have to use the line output of your sound card.
Page generated in 0.018325090408325 seconds with 16 queries,
spending 0.00581026 doing MySQL queries and 0.01251483 doing PHP things.
Copyright ©1999-2009 diyAudio.com
