diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Any suggestion for cheapest SET amplifier project - Click HERE for Original Thread
arnoldc
I'd like to make an ultimate, el-cheapo single-ended triode power amp that will deliver 2-3W of power.
will use hammond 125ESE as OPT, locally sourced power transformer and choke.
do you think 6B4 as power and 5687 driver is cheap enough? :scratch:
Colt45
I see our opinion of cheap differs somewhat..
I'd say something like 6BX7, 6S4, blah.. any cheap suitable triode w/ '$10 special' OPTs ;-)
Sch3mat1c
Yeah where's Fred Nachbaur when ya need him...
http://www.dogstar.dantimax.dk/tubestuf/miniblok.htm
Can't get much cheaper than him....err I mean that...yea... ;)
Tim
arnoldc
thanks for your suggestion guys.
maybe a 6S4 and 6922 then? if i get get 2+ watts out of that 6S4, i'm a happy man.
ShiFtY
I picked up a couple of Sovtek 6B4 (octal 2a3) for $US50 on eBay... They are pretty cheap and there are lots of schematics available. I am currently running mine at about 25W dissipation with 125ESE for about 5W of audio power. (which is surprisingly loud)
I used 3 separate power transformers I had lying around, built the power supply on a separate chassis.
Sounds really good, a little negative feedback helped though.
I have probably spent $US150 on this project total...
Tom Bavis
I hear that late model 6B4s from Sylvania were rebased 6AV5s with screen tied internally to plate. 6AV5s are about as common as dirt and almost as cheap....
But the 6EM7/6EA7/6DN7/6GL7 or miniature equivalents 6DE7/6DR7/6EW7/6FD7 will make about the cheapest triode amp possible. Only about a watt, though, in class A1.
DrewP
In recent ponderings (and having access to four of these) I've done a search and it seems that with the 2 halves of an 829 paralleled up and run in triode mode you can get around 4 or 5 watts of really nice SE from this tube.
Haven't tried it but there was a very short thread on Audioasylum tubediy (do a search on 829) where someone was running one at about 300v with a 2.5k tranny (IIRC)
NOS RCA of these are about 9 dollars.
**Special base required can be got from tubestore.com for around 7 dollars ea.
just a thought
drew
arnoldc
thanks guys. there's more options than i thought! i love DIY :)
Morse
Hi arnoldc;
Don't forget the lowly 6BM8 SET! Run in pentode mode you can get just over 3wrms from this little $8-$10 valve (complete with it's own triode input section!). While it's not as nice sounding as my 2A3 (with pricey iron and some "boutique" parts), it's quite good sounding.
Just do use more substantial PS iron than I did on my little 6BM8 - that 269JX is going to get replaced with a 270DX as soon as it arrives. Even that may be cutting it a little close, so I'll update everyone on my experiences there (hopefully it will run a LOT cooler than the current PS trafo...). The next step up is a 270FX, but I hope that's not necessary.
Pix to follow once a friend emails 'em to me.....
All the best,
Morse
john
Hi Arnold,
Try this 4 watter 6AS7 SRPP. This tube is a relative of the 2A3, 6B4G family. It's a twin power triode... Less tube count .
John
arnoldc
thanks morse. is your OPT also 125ESE?
oh john, are you referring me to some schematic or i misunderstood?
Morse
Hi Arnoldc;
>>>...is your OPT also 125ESE?...<<<
Nope. It's one of Ned's $10 cheapies from Triode Electronics. I may upgun to something like a 125CSE when funds allow (one consideration is that I am keeping the OPT's under the hood of this one - and that's a 17.8cm by 17.8cm by 7cm space for EVERYTHING but the valves and the PS trafo). FWIW there's a very real difference in sound quality between those junkers and the 1627SE's I used on my 2A3 - but then the little guys cost next to nothing and actually sound surprisingly good through the testbed RS 40-1354's I'm planning to mate with this one....
Anyway, if you can afford 125ESE's on this I think you will be very pleased - they are WAY better iron than what I used on my 6BM8.
Please do keep us all posted on your progress!
Good luck on your project and all the best.
Morse
john
Arnold,
Yes, I am refering to the schematic which U can use. i have built an 8 watts per channel using a Tamura 2007 output tranny.
By the way, I am also a Filipino. I reside in Pasay City. Maybe I can be of assistance to your El Cheapo SET amp.
John
siu sin man tho
hi,
pls see my laterest version kits
Any suggeestion was welcome.
thanks
thomas
arnoldc
thomas, it doesn't in any way look cheap to me!
john, tamura... argh! :) you must know michael young huh? where's the schematic found?
ok, let's set a threshold here ;) no more than USD100. fair enough? :scratch:
siu sin man tho
hi,
sorry I hadn't see all the previous.
vewry sorry for me & thanks for your opinion.
thanks
thomas
Morse
Hi Arnoldc;
>>>...no more than USD100...<<<
Is that for the whole amp, or just a part, like the OPT's? Sorry, but I'm not sure of your meaning from context.
If $100USD is the cost of the whole amp, including valves, you're down in 6BM8 turf - only 2 valves (since each contains both an input section and a power section) for stereo and a cheap set of iron, like the $10 OPT's I got from Ned.
One thing to definitely do right though is to NOT SKIMP on the PS trafo - I found that out to my regret with my 6BM8 (that 269JX was running HOT and it's successor is only 9 degrees C cooler - at least it's got plenty of overhead on the primary winding though). In Hammonds, you should not go below a 270DX, and a 270FX would frankly be a better choice.
If that $100USD is for a pair of OPT's I think that the 125ESE is your best bet - it's got lots of people raving about it these days and it's very adaptable.
If that $100USD is for all the iron together, I'd spend most of that money on the PS trafo and get the cheapest OPT's I could find to start with. OPT's are easy to upgrade, but a PS trafo is intimately interconnected with the rest of the PS. All your voltages will change when you change it and that can be a blessing or a curse, depending on circumstances. Best to get the heftiest PS trafo you can and plan to upgrade the OPT's later.
Just my 2 pence worth! Others here may well disagree on this approach.
Good luck on it!
Morse
arnoldc
thomas, no problem there, no offense meant :)
morse, i was hoping for the entire amp :devily:
power trafo is least of my problems, i have a very good winder where i recently have him wound a 300-0-300 @ 200mA, 0-5 @ 3A, 0-6.3 @ 4A, 2 x 0-2.5 @ 3A for about $9. he made made me a choke 20H 200 mA for $3.5 and 10H 200mA for $3 :shhh:
siu sin man tho
hi arnoldc,
very thanks. I had a little opinion for my different. The choke of power amp not use more than 13H, 10H is OK.
If U like to use large choke with small cap. Pls try double choke with small cap also better..
thnaks
thomas
Morse
Hi Arnoldc;
Hmmm, if $100USD is for the whole amp (including valves?) then if it were me I'd definitely go with the 125ESE's at the very most expensive; you might consider one of Hammond's slightly less expensive options like the 125CSE or 125DSC as well.
The rest of this is based on US availability and pricing. No offence, but I honestly have no idea of the availability and pricing of the following items in your country.
Valves - I really like the sound of the little 6BM8; now that I'm in my second 'mark' of this amp (improved PS, bypass caps, and cooling now provided with a 2.5cm x 2.5cm vent in the chassis directly next to the dropper resistor) I can see why the Japanese love this type of amp so much! It's dirt simple and it sounds way better than it should for the money spent. Also it's possible to make it VERY tiny - mine is only 21.6cm x 21.6cm x 8.9cm.
Caps - For coupling, go Sprague 716P 600V Orange Drop if you can get 'em, 715P 600V Orange drop if you can't get the 716P. They sound great and you can usually get a pair of 'em for under $4 here. For PS caps, Nichicon electrolytics are fine as are the new JJ's and the Sprague Atoms. However, the Atoms are a little more $$, and they're much larger than the other two types. The JJ's are the smallest if size is a consideration; the Nichicons are available here a little cheaper and they're only a little bigger than the JJ's. Whatever you use, I have found that bypassing them with .01uF 600V 715P OD's works terrific at removing grain from the sound. Also, don't forget to bypass your cathode bypass caps with something like a .1uF - .01uF polypropylene film and foil type - you'll be rewarded with a slightly smoother sound. The 715P OD works fine as do the "Dayton" caps that Parts Express sells here.
Rectification - The humble SS diode gets the nod for small size and cheap $$ outlay. I used the ubiquitous 1N4007 snubbed with 3kV ceramic discs I had laying around on my most recent amp. Figure that the cost of this approach will be less than a good socket for a rectifier valve, let alone the cost of the valve.... Also, you really should consider DC heating - it's much quieter and it allows for regulation of the voltage to the filaments. By all means, if $$ is a consideration, make sure that those filaments are not being given too high a voltage. Your valves will last much longer if you can keep the voltage within two or three percent of the nominal rating. If it's out by 10% or more, expect a shortened valve life.
Volume control - Nothing wrong with a carbon track potentiometer like the 100K Alps audio taper stereo pot that Radio Shack sells here for $3. I have a bunch of 'em on hand and I use 'em in all my budget projects.
Wire - ordinary 18-20AWG tinned solid core copper is easy to work with and sounds fine, regardless of what some of the further out 'high enders' might think. If you're in a real budget crisis, you can salvage wiring out of old computers and monitors that are being thrown out. Just make sure of continuity and the integrity of the insulating jacket before you use it.
Chassis - You can spend a lot of $$ on a prefab chassis, or you can make your own. If you make your own, wood is cheap but you have to make CERTAIN that it's properly dried, otherwise shrinkage, checking, and cupping are likely problems (particularly in view of the heat an amp can generate). If in doubt, a good sheet of 3.2mm thick aluminium alloy and a pine base are cheap and functional. If you've a sense of humour, you can use some of the darndest things for a chassis. I've actually seen a picture of a 6BM8 built onto a cookie tin (!!!) at a Japanese website. Be creative.
Valve sockets - I like ceramic, but there's nothing wrong with bakelite. The biggest thing is that I'd go with chassis mounts to help dissipate the heat via the top plate. I corresponded a while back with a guitar amp builder who swore that the valves lasted longer that way (and those guys should know - the guitar amp community tends to run 'em HOT for long hours); he also swears that the circuit boards (if any) last longer if the sockets are not mounted on 'em.
Jacks - I like the cheapie gold plated RCA's that Parts Express carries here in the states. Personally I do not like the Radio Shack ones; you may be able to find something locally that's cheap and good. Also you could consider BNC single ended inputs or balanced line inputs via XLR's if you are willing to build adaptors to standard RCA gear.
Switches - For power switches I just go to the local "Farm and Fleet" and buy a motor rated 250VAC 10A switch. Those suckers last forever and they're cheap ($2.5USD here).
Resistors - No need to break the bank here, with boutique brands. I like to mix and match carbon comps, carbon film, and metal films to get the right mix between warmth and detail. If you want to be stingy, just go with the cheapest carbon films of an appropriate wattage rating you can find (only place I steer clear of carbon comps is in the PS - they can be a fire hazard in the event of a big power draw through 'em). Then if you want to get some more detail, swap out the load resistors on the input valves with a metal film type. For a dropper resistor, you can go ahead and use a ceramic potted wirewound without guilt. Any extra inductance is a plus for removing high freq garbage. Just never NEVER use an inductive wirewound for a load resistor or a cathode resistor. You want something that's as purely resistive as possible for these functions.
Good luck on it - hope I've not put you to sleep with this!!
All the best,
Morse
arnoldc
hey morse, thats a heap of good stuff you got there! thanks! i've been looking for 6BM8 designs on the net and most are japanese ones. man, these guys are even using tamura opts for the 6BM8 :eek: this tube must sound real good :confused:
thomas, you got me really interested in your suggestion about no more than 10H on chokes. can you please elaborate or point me to a direction where i can find explanations?
Morse
Hi Arnoldc;
>>>...this tube must sound real good....<<<
Yep, it's got a sound out of all proportion to it's cost; I can hardly wait to get a pair of Hammond 125CSE's (biggest 125xxx's that will fit in this chassis). My 2A3 definitely outshines it, but not by the margin I would like it to - and it was about 10 times the cost of this little 6BM8! (Gad, it hurts to type that!!!)
You can see pics of that and some of my other projects at http://home.earthlink.net/~shidenkai/index.html Sorry, but I still haven't got the pics of my 6BM8 (a friend of mine hasn't emailed 'em to me from his place - no digital cam here). Pics of the 6DJ8 headphone amp I built are here: http://www.diyaudio.com/forums/show...&highlight=pics
By the way, what kind of speakers are you going to drive? I'd heartily recommend the Fostex line if you can afford 'em, and the Radio Shack 40-1354 if you can't. Another possibility would be the Radio Shack 40-1197 in a TQWT - it's a kissing cousin to the Fostex FE 103. Here in the states, both those RS speakers have been discontinued and you can often find them for as little as $3 each (!!!) when you can find them, that is. The 40-1197 is still available in Canada from what I understand albeit at around $12-$14 Canadian (sorry, can't recall the exact price).
Right now I'm driving a pair of RS 40-1354's in 10 litre cabs (salvaged from an "all in one" minisystem) with this 6BM8, and it's a sweeet combination. I can hardly wait to get some better cabs built for these speakers!
Before I forget, if you want to add amenities like multiple sources to your amp, you obviously are going to add to the cost in terms of a switch and some extra input jacks. Believe it or not, I used a simple DPDT toggle switch on this one (it was an afterthought) and there's none of the crosstalk problems I was told to expect by some of the "high endy" guys at another forum. YMMV, since I dug out an old industrial quality switch (gold plated solder tags and solid silver contacts) and I can't vouch for any other brand of switch in this app.
One thing I forgot in my other post was the importance of good signal wire from the input jack to either the selector switch or the volume control (if only a single source amp) - I usually use microphone wire with 2 conductors and a shield. It works fine to use each wire for a different channel and connect the shield to ground at only the source end.
Whatever you go with, you've got the right idea - start small, that way any mistakes will not be wallet killers (nor will they be as heart rending). And the moment you first turn it on and hear music will be just as magical with a $100 amp as it is with a $1000 amp..... :)
All the best,
Morse
arnoldc
hi morse,
my god, this may hurt too :scratch:
i have built a 2A3 integrated and started with 125ESE, then an opportunity came and i got MagneQuest DS-025 on this amp now.
then i made a 300B with Lundahl power tranny, and now the 125ESE is on this amp. May upgrade the 300B to Lundahl OPT so i can re-use the 125ESE.
after i made a Foreplay for about $69 u.s. dollars, i got the itch to make a cheap SET as well, thus this topic. ;)
right now, i have an infinity kappa 200 at 89dB sounds loud with the two amps i currently have (well, my third amp is gathering dust :( Anthem Amp 1 and Pre 1L). i've been trying out a pair of Coincident Tri Sigs recently and i heard it good driven by my friend's Monica (DC Darling). i may be able to try out a pair of Omega Grande 6 or Super 3, just maybe. :)
Morse
Hi ArnoldC;
Darn, that's some seriously nice stuff you've got there!!! Sorry if I sounded too preachy, but from the question I thought I was dealing with a first timer.
300B's, Magnequest and Lundahl iron, etc - that's better than my best! :-)
All the best,
Morse
arnoldc
hi morse, sounded preachy? nah, i learn more that way. is this what you did?
Morse
Hi ArnoldC;
Nope, it's not the Svetlana schematic. It's the one at http://www.diyaudio.com/forums/atta...=&postid=170718 with the following changes:
1. There should be another 100uF 450V filter cap after the 820r dropper.
2. The 820r dropper has now been replaced with a 1k2r dropper.
3. The PS trafo is now a Hammond 270DX.
4. The 22uF 450V filter cap after the 820r should be placed after the 4k7r dropper resistor to the screen grid.
5. .01uF 600V 715P OD's have been parallelled to all filter caps.
6. .01uF 400V Dayton film and foils have been parallelled with the cathode caps on the triode section.
7. The heaters are run on DC off a 4A 50V bridge from Radio Shack and filtered with a 3300uF 35V cap. Since the PS upgrade, I've parallelled a pair of .47r in series with the A+ to the heaters to bring the heater voltage down to 6.27V.
The operating values are now:
Raw B+ = 265VDC with .157VAC ripple (measured at second 100uF filter)
Total current draw on HT secondary = 85mA
Total AC ripple as measured at the binding posts to the speakers = less than .001V (inaudible with 89dB speakers).
Pentode section
Ip = 33.8mA
Vp (relative to cathode) = 226.4V
IG2 = 7.2mA
VG2 (relative to cathode) = 215V
Triode section
Ip = .57mA
Vp (relative to cathode) = 83.1V (measured at plate)
With the 270DX, I measured 40.7VA (total from all secondary windings) and 55.2VA drawn (measured across the fuse on the primary); obviously the difference is the waste heat. For this reason I would honestly advise the use of at least a Hammond 270EX if not a 270FX.
Hope this is useful for anyone interested in a similar project!
Sorry for the delay in answering but for some reason the forum was not accepting replies to this post last evening. Ain't computers grand?! ;)
All the best,
Morse
arnoldc
hi morse! i think i would just use your design then. you wouldn't mind would you? :scratch:
and how many watts will this l'il amp put out?
Morse
Hi ArnoldC;
No problem; you might want to make a few revisions to better manage heat issues though.
I've not checked the watts of power out on an o-scope to be sure but it should be a little over 3 watts per channel rms at clipping; that fits with all the valve manuals, manufacturer's data, and direct comparison to my 2A3. Bass response is definitely hampered by my use of cheap iron, but with the 125ESE you'll have no problems there....
The biggest single thing to bear in mind in this design is the amount of waste heat generated by two sources - that 1k2r 25W ww dropper resistor dissipates an honest 9 watts of heat and the PS trafo itself is dissipating something like 14.5 watts of heat. My chassis design didn't really manage heat as well as I would have liked, so it's under revision (extra cooling ports, etc). For cooler operation, you could go to a CLC along with a lower voltage PS that has deeper current reserves, or you could just substitute a heftier PS trafo, currentwise. PSUD II is really helpful there!
One personal opinion is that I'd steer clear of Ei's 6BM8/ECL82. If you check the recent thread on the quality of Ei products, you'll see that my most recent Ei 6BM8's were substandard in quality. That's just my personal opinion though. Anyway, there are plenty of NOS RCA 6BM8/ECL82's out there, along with Svetlana's version and they seem fine!
Good luck - I just wish I had some pics of this one that I could post.....
Morse
planet10
quote:
Originally posted by Morse
Wire
30 guage wire wrap wire is really good, a bit fiddly to work with thou
quote:
Chassis ... Be creative.
check out the aluminum pan section of the local 2nd hand store.
quote:
For power switches
Or yo can just use the pull the plug out of the wall method.
$20 Canadian. 5% off if you use the appropriate CC, 10% off for 10 or more.
I was doing up an SEP 50C5 and was wondering about the way the screen was wired in the Mk 1. How does this map look for the Mk II (i'm going to crib off Morse -- just found another SE 6BM8 in my parts collection).
dave
arnoldc
dave, thanks for the additional info.
morse, though i'd like to get one "commercially," my friend just threw a couple of Mullard ECL82 at me :eek: so how can i resist :cool:
looks like this project has got to start :devily:
cost so far:
5K OPT $8 x 2 = $16
Power trafo $10
10H Choke $4
ECL82 Free
$30 dollars so far...
Morse
Hi Dave;
Thanks for reposting the revised schemo; since I'd missed the mistake with the screen grid in the posted Mark I schemo (it was always wired as it is in the revised schemo), I can tell that proofreading is not a career I should consider at this late stage in my life!! ;)
Yep, if you build the same circuit you'll be happy - I'm listening to mine through the 40-1354's in 10 litre junker cabs and it's gooood. Violins have a 'real' feel to 'em in classical music, and voices in pop music are 'right' - particularly oldies like Louis Armstrong, Frank Sinatra, Fats Domino and Sam Cooke. The sax accompaniment to Fats frankly outshines my 2A3's rendition of it (*sigh* - time to do some revisions on that amp now....maybe pull the cathode follower and go SRPP or to interstage trafos if I can scrounge up a pair cheap).
Also thanks for the corrections to the RS Canada pricing - I'd remembered it wrong! (early senility over here? who knows?).
One small revision (Mark IIb?) was the replacement of the 220kr 1/2w carbon film load resistors on the triode sections with 220kr 1w NTE metal films. It yielded a little more detail at the expense of a tiny bit of warmth. Overall I like the increase in detail, but that's a combination of personal taste and voicing with the other components used.
Hi ArnoldC;
$30 USD with most of the goodies, a good choke for the PS, 125ESE's and Mullards to boot (drool, drool)!! You're going to be mucho happy with that!!
All the best,
Morse
fragman56
Hi Morse,
Just a quick question: Eric Barbour's design on the Svetlana page shows the output of his 6bm8 sep as about 1.5 watts out. The datasheets show over 3 watts out in pentode mode.
Svetlana design specifies B+ range--does this explain difference in power out?
Rick
Morse
Hi Rick;
Re: the Svetlana design, I think you are right. If you take a look at the graph of volts vs distortion in the corner of that one, you'll see that they go all the way up to 5Vrms into an 8 ohm load which translates as 3.125 Wrms with a 400V plate.
All the best,
Morse
planet10
My 1354s are still sitting on the shelf... they will be going into a set of bipolar ML-TQWTs. (and i have some more on the way so i can try out a couple other option too)
dave
PS i fixed the Mk 1 map.
Morse
Hi Dave;
My Gawd, those are beautiful speakers (drool, drool)! Great workmanship!! I've thought about building a set of T-lines for years (and admired your site - my compliments) but don't have the space for 'em at the moment.
For the future though, do you think that a 2 driver bi-polar TQWT using the RS40-1197 would have any potential? I've managed to track down 9 of 'em since RS USA closed 'em out and I've thought about building a set of 4 of 'em for a HT system I'd like to build; I'd shield the drivers for the centre channel and mount 'em in a midget BR for under the TV use. If necessary I could probably substitute an FE 103 for the front driver in the bi-polar centre channel (should I be unable to find another 1197).
I'd probably power it with a 5 channel 6BM8 SEP, now that I'm getting a feel for designing with this valve. It's cheap and I like the sound.
All the best,
Morse
PS - Thanks for revising that MK I schemo!
planet10
That is just the 3D computer model. On some thread or othr i posted a pic of some cabs for some PHY 8s -- that is the sort of cosmetics -- we haven't finialized it yet (ie trying to avoid spending the big bucks on materials)
quote:
For the future though, do you think that a 2 driver bi-polar TQWT using the RS40-1197 would have any potential? .... If necessary I could probably substitute an FE 103 for the front driver in the bi-polar centre channel (should I be unable to find another 1197).
Chris & I have built quite a few of the BD-Pipes w 1197s -- they are fine (with suitable driver mods). We are now working on a design specifically for the 1197. The 1st iteration are centre channels using coincedent driver magnets for shielding.
The 1197s need a little help above 10k -- an ApexJr 14mm tweeter + 2 uF cap works well (we puesdo horn load them)
dave
PS i have lots of 1197s if you need a single.
Morse
Hi Dave;
Wow, those are some terrific looking computer graphics you've generated! I feel really old, being from the pre-graphics 'mainframe computer' and slide rule era.... Anyway, they'll be terrific looking speakers when you build 'em.
Thanks for the data on the 1197 BD's. That's pretty much what I had in mind. Thanks also for the offer of selling an 1197 so I can complete my set for that one; I'll email you on that soon.
By the way, one late mod to the Mark II amp was a cooling fan under the chassis - it did a terrific job of moving heat out from under there, but it was way to noisy. Back to the drawing board on that one. Maybe some kind of baffle arrangement and an internal mounting to let the fan circulate air without being annoying? Hmmmm.
However, one mod that has worked well was the fitting of some .068uF 600V polypro caps I had laying 'round to bypass the decoupling caps to the screen grids. Sounds a tiny bit smoother now, and vocals sound a bit more natural (Less sibilance? I'm not sure - it's a subtle effect).
All the best,
Morse
planet10
Hey, i started on mainframes, with punchcards when graphics were carefully layed out arrays of characters. I did get an HP25c 1st year of university and slowly got to put away the slide-rule -- thanx for the complement thou (i was always a drawer and MacPaint & MacDraw got me started on serious 'puter graphics.
The plans and scematics are really quite simple... one of the favorite graphics i've done is this:
(picture deep linked from HD3D Movies)
We have 2 variations of these built already. I just need to add drivers and play with em a bit.
dave
john
Arnold,
Yes, I know Mr. Mike Aw Young. 100 usd for a SET stereo amp? Well, it would boil down to DIY all the way from chassis to trannies. I myself wound my own trannies and make my own chassis. It is possible also on your part for a 100 usd budget. The hard part is to hone your skills and be a craftsman.
Comeby and visit me sir in case you have time,
John
arnoldc
john,
yes, DIY from chassis to trannies (not me doing it though) :-)
i sent you an email. ;-)
plovati
We're trying to design a 100euro Hi-Fun SET amplifier:
several version designed:
http://www.cdsoftware.it/primo/mate...IMO_3000ohm.pdf
http://www.cdsoftware.it/primo/mate...IMO_5000ohm.pdf
and the power supply:
http://www.cdsoftware.it/primo/mate...entatoreRev.pdf
and some cheap output trafos:
http://www.cdsoftware.it/primo/mate...afo_JunkBox.pdf
italian text, but with some cooperation we can put it on english word document, if some people interested in cooperate.
Page generated in 0.14125800132751 seconds with 17 queries,
spending 0.01916289 doing MySQL queries and 0.12209511 doing PHP things.
Copyright ©1999-2009 diyAudio.com
