| Forrest |
Maybe folk could use this thread to ask quick questions about their enclosures...or ohp mods
i currently have two 6cm 12v fans spinning away one at the back drawing air in and one at the front sucking it out...
Is this the best way or should i have two sucking in or two sucking out, beasically looking for the best way to get the hot air out of it....
Thanks in advance...
Forrest |
| Property |
| Two blowing out and one sucking in would definetly be better than 2 blowing in and 1 sucking out. Hope that helps. |
| Video Freak |
| Honestly when we do Hoods for large aquariums( 5-6, 400watt MH lights) we always have the fans blowing out and just have holes for the intake, the best way I have found is holes at the bottom( same size as fans) and the fans at the top blowing out. thats My WHOLE 2 american cents. |
| jcbklyny |
Believe it or not intake fans screw up the air flow inside the case itself.
Your best bet is a blower type fan for the light assembly blowing directly on the light / ir filter itself and one or two outtake fans. |
