diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
RIAA Audio Standards - Click HERE for Original Thread
TJtsj
I have been working on the amplifier that has been mentioned in some other posts (http://www.astro.uu.se/~marcus/private/m250.html) and I am running into a few questions. Basically I just need to know what the standard signal levels for the RIAA are. Like what would come out of the line out of my home stereo.
peranders
Out from the RIAA amp, you mean? 300-1000 mV. Line level is a floating value, have I noticed. It is also dependent of the pickup.
My monster RIAA amp has gain of 1848 = 65 dB at 50 Hz. This level is OK for my pickup (Ortofon FF15) and pre amp.
EC8010
There aren't any RIAA standards for levels, it's all down to how much level the cutting engineer is prepared to put on disc. Higher levels reduce recording time and risk mistracking on subsequent playback. Conversely, lower levels reduce signal to noise ratio, but allow you to cram Beethoven's 9th on one LP. Typical (equalised) peaks reach 12dB over 5cm/s.
TJtsj
Ok so either I’m not getting the picture or I didn’t make my question clear enough... I have the amp built that I mentioned in my previous post. It takes a 4.4Vp-p signal to make the output of the amplifier start clipping. I have learned that my CD player doesn’t even come close to that. It’s more in the range of 500mVp-p. Is my CD player just odd or am I going to need a pre amp to get the full potential out of this amp?
fdegrove
From what I read I gather your a bit at a loss as to why your phono stage delivers more signal than your CDP?
Cheers,;)
EDIT:
Question is, what's the input sensitivity of your amp?
TJtsj
Hmmm, so I guess from what has been posted that every device from a home theater receiver to a CD player, to a computer has a different line-out peak voltage. Am I so far off that even GPS can’t find me or am I finally making sense. So if there is no standard does that mean that I have to add an AGC (automatic gain control) to my amp so that I can get the full potential from it?
:idea: :confused: :confused: :confused: :confused: :confused: :confused: :confused:
BrianL
The thing you need is called a "volume control". Maybe also
a preamp.
CD audio is supposedly standardized so "full scale" output
is fixed (2V rms, I believe, or thereabouts; maybe it's 2V pk).
It's part of the nature of representing your signal in digital
form that there is a maximum full-scale "level" represented
by the bits.
Analog systems, be they magnetic tape, phono, broadcast,
etc., have no hard full scale limit -- it's somewhat "soft"
and dependent on many factors. (ulitmately, of course,
the circuitry can't put out a bigger signal than the power
supplies allow).
To use a somewhat defined standard, nominal "0 VU" on
professional tape machines are set to 180 nW/m or 250nW/m,
or even other standards depending on tape type, etc. But
even given that your machine is set to a particular one,
you can easily put peak signals onto the tape that are 10 dB
or more above this nominal operating level.
In analog, there are various reference levels such as the
above-mentioned tape levels or a phonograph disk level
of 1 cm/sec or broadcast standard of 100% modulation
(AM) or x kHz deviaion (FM), but these are just nominal
(and somewhat arbitrary) levels chosen for that particular
medium to use as a reference for technical performance
measurements. These do not represent the maximum
signal levels that can be put onto the medium.
There are some fancy preamps, both DIY and commercial that
give you a gain/attenuation adjustment for each input so
that you can have roughly equal volumes between sources
when switching from one to another.
TJtsj
Ok now I get it. I think all the EMI from the labs I have been working in has finally messed with my head. I have determined through testing that nothing other than a function generator seemes to put out the voltage i'm looking for. which means a pre amp is in order.:idea: :nod:
MarcelvdG
I don't know if the situation is different in the USA, but down here in the Netherlands there are rather strict limits on the frequency deviation of FM transmitters. In the good old days +/-75kHz was the limit. Nowadays there is a spectral mask defining how strong you can modulate your transmitter without loosing your license, but for practical music signals, this spectral mask still corresponds to roughly 75kHz peak deviation.
On the other hand, for commercial reasons, many stations want to sound as loud as possible. That is why they use terrible multiband compressors and clippers to increase the perceived loudness while still complying with the spectral requirements. The pop music stations sound particularly dreadful.
Regarding AM: some transmitters cheat by increasing their carrier power somewhat in loud parts of the signal, but otherwise you cannot exceed 100% modulation without turning the signal into a kind of DSB instead of AM, which can no longer be properly demodulated with a precision rectifier.
However, there is no real standard for the demodulator constant of AM and FM tuners, so you can still get about any level out of your tuner.
TJtsj
quote:
Ok....... um I never said that I was transmiting signals using FM or AM. I simply have an audio amplifer for my home speakers... people seem to be over analyzing my question. Not that I am not gratefull for the help people try to provide, but that's way far off topic.
Jocko Homo
I usually shoot for 0.5 V rms, using the standard 5 cm/sec 1 Khz test tone.
Jocko
PGW
Sounds reasonable...
or 0 dBU = 776 mV rms (into 600 Ohms, for the purists).
EC8010
0dBu = 775mV RMS and is the voltage that would have dissipated 1mW in a 600R load, but it does not specify an impedance.
0dBm = 1mW into 600R. But this is virtually impossible to measure (most meters calibrated dBm actually measured dBu).
AuroraB
And there is also the the 0dbV = 1V, as used by a lot of studio equipment of today...this one also being impedance independant.
The 600 ohms nominal load seems to mostly for measurements and calibration purposes.
Most units today will be rated around 1V sensitivity, or contrary, output level. This is of course not the same as clipping level, which is design dependant.
Older units, like cassette decks of european origin, often had 100-200 mV as nominal output level, whereas the japanese were among the first to somewhat standardise 1V, or thereabouts..
Cirka thereabout is probably the closest we can get....
CDs vary quite a lot, in terms of max output, or full scale level, and this is both the actaul discs themselves as much as the players we use. Personally, I cannot recall ever having seen a calibration level for CDs...??? Anyone else??
EC8010
600R is historical, and comes from the days when wires strung on telegraph poles had a measured characteristic impedance of 600R. Before anyone starts wittering about transmission lines and audio, I must emphasise that for transmission lin effects to become noticeable, the cable length has to be a reasonable proportion of one wavelength. In audio terms, that means miles, not metres.
The specification for CD players is that a maximum amplitude sine wave (using all possible bits) should produce 2V RMS. Early CDs didn't use all the bits because of metering problems during mastering.
Modern CDs are recorded at greater resolution, then tweaked so that they just avoid 16 bit digital clipping. Also, the CTF control is turned right up. (Compressed To F^*&)
Jocko Homo
0 dBm is 1 mW into a 50 ohm load........0.224 V rms.
Jocko
EC8010
Thank goodness we hardly use dBs for video. There, we have 1V pk-pk into 75R.
AuroraB
and dBuV for R/TV signal strength........:bawling:
tubetvr
This is not a correct definition of dBm, 0 dBm means a power level in dB relative to a reference power of 1 mW U]regardless[/U] of impedance.
So for 50 ohm 0dBm is 1mW = 0.224 V RMS measured over the load.
and for 600 ohm 0 dBm is still 1mW but 0.775V RMS measured over the load.
Regards Hans
Jocko Homo
Didn't I say "in the RF world"???????????
Jocko
moamps
In my country still is.
Channel (station) separation is 200kHz.
Professional FM receiver has +4dBm output for 75kHz deviation with 400Hz typically.
In audio dBm ultimately is 1mW/600ohm=0.775V.
Oupsss. Terrible compressors are single band. "My" old ORBAN OPTIMOD-FM 8100A/XTA isn't. There is more reason then "only loudness" for using smart compressors. ;)
tubetvr
Yes you did but in the RF world it is quite normal to have other impedances then 50 ohm like 75ohm. 0 dBm is 1 mW regardless of what impedance you are using.
Regards Hans
(working in RF design since 1983)
PGW
A nominal output from an RIAA-equalised preamp may be (say) 0.5V rms at 1 kHz. How are you performing this equalisation?
It's worth bearing in mind that the 'raw' signal before equalisation is 10 times larger at ~20kHz than it is at 1 kHz, and 10 times smaller at 50 Hz. Does your preamp need to handle these 5V rms signals prior to equalisation? What 'headroom' for transients and peaks will you need?
A general question regarding the RIAA equalisation: the upper tine constant in the RIAA spec is 75 microsec = 2121 Hz: the filter just carres on forever beyond this. I read somewhere recently that adding a zero in the response at ~37.5 microsec, to counteract the RIAA low-pass action at ultrasonic frequencies yields better audio performance.
Any comments, supoortive or otherwise, of this assertion?
-- John
EC8010
quote:
Yes, but sometimes it's hidden. It all depends on the gain structure of the individual pre-amplifier and the way that the equalisation is implemented. If NFB is used, we need current rather than voltage headroom. Delivering current with little voltage is equivalent to a vertical loadline, so distortion rises before feedback. Altenatively, passive equalisation can be used. Because of the 20dB (1kHz) loss rwequired by passive equalisation, it is difficult to satisfy noise and headroom requirements simultaneously. One solution is to split the equalisation, and do 3180 and 318 in one stage,and 75 in another. These stages can be active or passive, or a combination of the two.
A magnetic cartridge is a velocity transducer. It's output rises at 6dB/octave with frequency. If you apply a transient to it, you can expect a lot of HF energy (particularly with moving coil cartridges where the stylus tip mass/vinyl resonance is quite pronounced). The most common transient is dirt or a scratch. There is no such thing as too much headroom in an RIAA stage.
mrfeedback
Yes, very true.
A bad sounding phono pre-amp emphasises surface noise, and good sounding ones do not.
Good sounding preamps filter the HF stuff first and have relatively high voltage supplies to ensure adequate headroom throughout.
Eric.
Page generated in 0.068721055984497 seconds with 17 queries,
spending 0.00983286 doing MySQL queries and 0.05888820 doing PHP things.
