diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
What tube to use. - Click HERE for Original Thread
aurche
I would like to build an headphone amplifier. The concept that i have made up is: OTL, Ultra Fast Diode Rectifier, Relatively low voltage, One Tube channel. What tube would you suggest i use?
And mind that the output impedance must be 50 or below!
aurche
I was thinking 6S45P
azazello
Yours headfones - low impedance /30 - 60 ohm/ or higt /200-300-500 ohm/?? It's very important!!!
aurche
Nikola, 55Ohms.
astouffer
http://headwize.com/projects/index.htm#tubes
Akita
You can try 6as7. Its a nice tube for headphone amp too
azazello
6H30C - /Russia/ lake pre-amp, and 6H13C/Russia/ lake output
kathod.
Gordy
6S45 = 6C45 ?
Simple 6C45 power amp here:
http://www.paeng-design.com/devices_frame.htm
(in section: High ó tubes, Part 111)
Adapt to headphone by changing transformer ratio?
6C45 datasheet suggests limited input swing / bias, so will need attenuator at input if using 2V output from CD player.
Anecdotal evidence suggests 6C45 oscillates easily, so use well regulated supply and grid stopper resistors.
More info here:
http://www.vt52.com/info/measure/6s45/6s45.html
...and also in projects section of the site.
Good luck. : )
regal
I don't think you wil be able to power 55 ohm headphones with a single tube OTL. You will need push-pull with feedback to be output transformerless. Or you could use a solid state buffer with a single tube gain stage.
Page generated in 0.023505926132202 seconds with 17 queries,
spending 0.00788832 doing MySQL queries and 0.01561761 doing PHP things.
Please support our sponsor.
