diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Power Requirements for Multichannel Gainclone - Click HERE for Original Thread
Gcollier
What kind of power requirements should I expect for a 5 channel Gainclone (LM3875) delivering 30-40 Watts into an 8 ohm load. Would a 750 VA toroid (24/24 V 15A) do the trick? I assume this should give 150VA per channel which should be just enough.
What would be the best way to wire this kind of setup to reduce crosstalk?
Remember you are talking to a newb here so try to keep it simple:confused:
ThanX
Gcollier
Thanks guys I got my answer from another thread.
Page generated in 0.046689033508301 seconds with 16 queries,
spending 0.01814342 doing MySQL queries and 0.02854562 doing PHP things.
