diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
First guitar preamp... teake a look please. - Click HERE for Original Thread
cufunha
I'm graduating this year (electronics engineering) and I play guitar for a long time. I like to play metal (symphony X, angra, metallica).
I don't know much about guitar amplifiers; all I know came from google. It seems like guitar pickups act like a lowpass system with a ressonant frequency varying from 1kHz to 5kHz, and this transfer characteristic must be compensated (how?) in the pre-amp stage.
I'm trying to design a pre-amp, as simple as possible, just to start learning about guitar electronics and, in the future, design my own pre-amplifier for my guitar.
I have scketched a very simple pre amp based on poor solid state components, and it has a very good sound.
All I want now is suggestions on what to do next or what is wrong in this schematic and should be changed.
Please take a look:
lineup
Hola!
I think your little guitar ampifier is good.
You say: 'sound is good'
Why you want to change?
Some problem?
Only thing I do not know about is where you connect output?
Some power amplifier?
What is input impedance of your power amplifier = The Load?
What would I change?
I do not know.
TL081 / TL082 / TL084 will be good for this type of guitar amp.
12 Volt.
What power supply you use?
You want to use battery?
You can use TL06X variant: >>> takes only 200uA supply current! ( 0.2 mA )
And you use one 9 Volt Battery.
And you can put Battery + Guitar Amplifier inside your guitar!
Then you can turn and control, when playing.
Datasheets .. for VARIANT of Op-Amplifiers:
http://focus.ti.com/lit/ds/symlink/tl084.pdf
http://focus.ti.com/lit/ds/symlink/tl064.pdf
:cool:
cufunha
thankx for the answer. I forgot to mention some things. First, the output is connected to a standard stereo amplifier, I think a load impedance of 20k to 100k (which is connected to the 22k resistor shunt to the diodes).
the reason of 12V: it's the source I have here... it could be 9V without any problem...
about the 'good sound': the sound is clean (not noisy). It has a good distortion, but it doesn't have that metal sound i want. I have read about pickup electronics and pre-amp pickup corrections. What kind of corrections (filtering) are made in guitar preamps?
and the last question: what do you suggest to add to this schematic and how it is done?
thankx again for the answer.
lineup
I do not see anything add to your schematic, besides some metal effects you want.
One idea I have used,
when have mono signal input + output to stereo:
Put 2 output capacitors and output level potentiometer:
to left + right stereo channel
Same as using a mixer with 1 microphone (mono mic) input.
- you have 2 output to left/right.
- can use those 2 potentiometers to put this sound source into LEFT/RIGHT panorama
... when reording in stereo.
It is like panorama studio mixer.
I give you one good link to find metal guitar effect ... and some other good electronics circuits.
Because I know only little about guitar circuits.
Here I hope you will find a lot links for Guitar Circuits applications
http://www.epanorama.net/schematics...cuits/index.php
http://www.epanorama.net/links/music.html
Regardas honores.
Lineup
thespeakerguy
but a seasoned analog engineer;
C2 can be decreased. 0.22, or even 0.1uF, smaller and cheaper
C5 should be incresed, this is rolling off your gain st 160Hz right now. Becuase there is a fixed DC offset, a 22uF or 47uF electrolytic can be used.
R8 will not provide a reasonable volume range due to its interaction with the feedback diodes.
You will never get more than about 0.6Vpp out of this. Is that enough?
cufunha
i changed R8 to 500k now and now i can clearly hear the overdrive effect i want (but too noisy because of the very high gain). the capacitors are now changed as you pointed.
Can u explain me what should be the low cutoff frequency of this amp? I thought it was about 200Hz or more, but you´re talking abaout 160Hz.. and how about the high frequency cutoff? 10KHz is fine?
PS: inductor and capacitor near source simulates guitar pickup plus cables.
Page generated in 0.036097049713135 seconds with 17 queries,
spending 0.00745773 doing MySQL queries and 0.02863932 doing PHP things.
Please support our sponsor.
