diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Amp power supply - Click HERE for Original Thread
siming.guo
I'm very new at this, so this question may be very stupid.
While researching, I found many circuits for amps and filters that people made where the power supply provided only a positive voltage in addition to ground. I was under the impression that the sound signal from the computer was composed of sine waves, which have both positive and negative components. How can a circuit or chip that only has a positive rail amplify both the positive and negative parts of the signal?
pacificblue
By using the ground as the negative rail and creating a virtual ground at half the positive rails voltage.
Nationals application notes usually offer one example of how to do that with a transistor and a few resistors and capacitors. Some ICs, e. g. TDA2030 have that circuitry built in.
Page generated in 0.015559911727905 seconds with 16 queries,
spending 0.00765133 doing MySQL queries and 0.00790858 doing PHP things.
Please support our sponsor.
