| Buzzy |
Can a speaker cable like canare 4s11 be used as a wire for internal wiring of a DIY amplifier ? I see that on canare website it states that it can be used for DC power line.
I need your opinion on this .
Thankz. |
| nelsonvandal |
| I can't see why it couldn't be used. Any cable could be used if the dimension's right. Some people believe in the magic of cables and some don't. |
| nigelwright7557 |
| quote: | Originally posted by Buzzy
Thankz. |
So long as you use a good quality cable you should be fine.
Some cheap cable can be quite resistive.
I did a project for a surveliance system using cameras on quite long runs of wire. I did some research into different cables and was surprised at how good some cable is and how bad others are for voltage drop. |
| Gordy |
The simple answer is 'yes, it should be fine'. |
| nigelwright7557 |
| quote: | Originally posted by Gordy
So long as it can carry the maximum current in the amp. |
| unclejed613 |
| yes it will work well. remember to keep yput P/S wires short and away from input/vas stages. no matter how big, they will generate the same magnetic fields. |
