diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Oscilloscope Tektronix 465B, 475, 2336YA or ??? - Click HERE for Original Thread
TheDriver
I am a second year electrical engineering student and I am looking to buy an oscilloscope. I am under the impression that I could learn more about what I am doing if I could see what is happening. Currently I am working with AM transmitters and receivers operating up to 1.710MHz. I have built a gainclone amp in the past and cannot accurately predict what my future needs are.
My budget is $450 but my target price would be $250 or less. From my research on this board and others, I am leaning towards a used analog Tektronix. I have been looking on ebay and have notice the 465B, 475, and 2336YA to fit this budget.
Something I would like to do with an oscilloscope is measure the difference of two channels. For example, measuring the difference of the input and output of an op-amp to see the effect the op-amp has.
Any recommendations on what models or specifications to be looking for?
Is there a website or resource that explains the differences between the older Tektronix?
Thanks,
Matt
jackinnj
There are a lot of resources for vintage Tek and HP:
just put Tektronix vintage in your search engine.
http://www.chiark.greenend.org.uk/scopes/tek.html
FWIW, the 2465B was the Cadillac of analog scopes -- and there are still guys who service them. There is a 2465B with GP-IB on EBay at the moment. I have 2 scopes on my desk -- one is the 2465B and the other is a TDS3012B.
If you have a lot of room you can get a 7000 series -- these are real boat anchors with enormous functionality -- but they are the size of a couple bread-boxes.
One to avoid -- the Tek 2215 CRT is easily damaged if you bang it around. Not a good undergrad scope.
x-pro
My 2 cents:
If you are serious about your scope, save some money and get this one:
http://cgi.ebay.co.uk/ws/eBayISAPI....:MEWA:IT&ih=005
It will be better for most things that anything new up to $3-4K, IMHO.
Otherwise get a simpler Tek cheaply, like this one:
http://cgi.ebay.co.uk/Tektronix-221...idZp1638Q2em122
it will be enough for a good start and it is light and easy to carry.
Cheers
Alex
jackinnj
Before purchasing a 2213 I would want to be sure that it doesn't use the same CRT as the 2215. The mesh is easily deformed with rough handling making it difficult (if not impossible) to focus/astigmatize
Conrad Hoffman
The 465B is a nice scope, but they're getting on in years. Unless you're good at servicing gummed up controls and dealing with "five lbs of ---- in a two lb sack, I'd stick with something newer. I find having a good differential amplifier is important, but you need a scope with separate plug-in's to do that. The 7000 series is large but very good and takes plug-in's. There is a smaller series that's similar, but the construction quality isn't as good. Avoid analog storage scopes. IMO, there's no reason to spend more than $200 on a scope if you shop around.
x-pro
quote:
AFAIK, 2213A uses a different (brighter) tube from 2213 (and, presumably, 2215 too) . I have 2213A in my home lab as a spare scope and previously it did survive a very rough 20 years in a factory enviroment quite happily.
Alex
spind
I just picked up a second Tek 475 scope that I don't really need. It cost less than your $250 lower limit, but it will need a little servicing, if you are up to that (horizontal trace is tricky to get 'motionless').
Steve.
x-pro
BTW, if you are working with AM signals most modern digital scopes (especially cheaper kind) could be practically useless for a proper work. Here is a simple 1kHz AM modulated 1 MHz carrier observed on my Tek 2465B and an attempt to look at the same signal on my digital Agilent DSO3062A . You can not really see the AM envelope properly on a digital scope unless you have a very deep memory option (keeping a high enough sampling rate for slow horisontal sweeps) .
Alex
jackinnj
Reminds me of working a pair of 6146's on 80 meters with full plate modulation from a pair of 6L6's -- back in "the day" when SSB was much more difficult.
Doesn't your Agilent have an "Envelope" button?
Ham Radio Proverb "... a digital scope doesn't lie, it just doesn't tell the truth all the time..."
x-pro
No, only "peak detect", which works a bit better for a reasonable ratio of a carrier to a modulating frequency. TDS3012 is a much better scope than my Agilent but also much more expensive. At work thought I still prefer an old Tek 2465 to TDS3032 for analogue jobs most of the time.
Alex
TheDriver
Thanks for all the info! The 2465B looks great and I can see myself getting one in a year or two. But for right now I think the 2213A is the way to go, financially speaking.
I noticed though that the other 2213As on ebay have different and more buttons the the one Alex mentioned. Is that a 2213A pictured or a 2213? It is hard to see but I don't think there is an A on the model number pictured. I have attached a picture highlighting the differences in buttons.
Ebay item in question
Example 2213A with different buttons
Another example 2213A with different buttons
x-pro
One on the right is correct 2213A, on the left it is a different model - well done for spotting that, as it is certainly not 2213A and the seller from the link I've posted misrepresents the item.
On the other hand 2213A from your link looks good and price is OK.
Cheers
Alex
P.S. - the other scope looks a bit like 2213 without "A" , it is an older type and the tube is not the same.
TheDriver
Are there any other differences between the 2213 and the 2213A besides the display?
I found specs for the 2213 and 2213A at the the links below and the displays appear to be the same. Are the displays different and just have the same general specs?
http://www.testequipmentdepot.com/u...3&2215specs.htm
http://64.233.167.104/search?q=cach...clnk&cd=1&gl=us
Thanks,
Matt
x-pro
http://64.233.167.104/search?q=cach...clnk&cd=1&gl=us[/url]
Thanks,
Matt
Hi Matt,
from what I can remember the specs are the same, but the tube is different (as well as the circuit) and 2213A has a different arrangement for focusing. In general 2213A is later and better model.
Cheers
Alex
TheDriver
What about the 2215A? There seems to be more of them available at lower prices than the 2213A on ebay.
I have to admit the more I think about the 2465B the more I just want to wait. But maybe if I could get a 2213A or 2215A for dirt cheap, less than $150, that would take care of my needs till I could afford a 2465B.
Thanks,
Matt
x-pro
Thanks,
Matt
the only difference between 2213A and 2215A, I think, is that the latter is equipped with a dual time base (i.e. you can "zoom" on a portion of the signal by displaying it on a different time scale). It is a useful feature however there is no point in getting anything in a poor condition. Old scopes more often than not have problems with CRT, blurred traces etc. Unless there is a very good picture of a screen with a signal from the actual unit I would be wary of buying a scope very cheaply from an unknown source without some warranties or at least a money back option.
Cheers
Alex
Zung
I bought a 2236A last year for less than $200, calibrated, from a guy who runs a used test equipment business in San Diego. Maybe that'll suffice for your need.
Cheers
TheDriver
Thanks for everyone's help!
I ended up buying a 2235 off ebay shipped for $252.50. The scope appears to be functional and clean.
Ebay Listing
Thanks again,
Matt
Zero Cool
I have owned many Tek scopes and the 465 is a good solid reliable scope. I do not like the 2230 series.
I currently own, and have owned several in the past the Sencore SC61 service scope. this is a nice dual channel 100mhz scope with some nice features. There is a digital meter built in and that allows you to not only see the waveform but measure either Volts P-P, DC Volts, or frequency. plus it has a delta time function that is really handy for measuring the width of a wave or part of a wave or marking a specific time event. very handy.
The biggest drag of the sencors is that you have to use there probes for the Digimeter function to work and the dang probes can cost as much if not more then the scope!
These can be had cheap, under $200 generally and for a student that make a great starter scope! very easy to use. yet pack a lot of features. I would be hard pressed to give up the SC61 these days. maybe and i mean only maybe for something like a Tek DSO with VGA output or something.
Zc
TheDriver
Zero Cool,
Any reason(s) why you don't like the 2230 series?
Zung
A "real" Tek is built like a tank; the 22xx serie is light weight and feels cheap, and those are the 2 reasons I chose it: I had to carry it home :)
Christer
I just happened to stumble on a reasonable deal for at Tek 475 here in Sweden. However, I am curious how old it might be. Is there anywhere one can find info about the mapping between serial numbers and years?
I also got a complete service manual in the deal. However, I now realise that the scope is probably older than the service manual. The manual is the 1976 revision and applies to serial numbers from B250000 upwards, while the scope has a serial number just over 102000. Does anybody know if there are any major differences to be aware of, or if I can assume the service manual is close enough also for my scope?
Page generated in 0.065069913864136 seconds with 17 queries,
spending 0.00834894 doing MySQL queries and 0.05672097 doing PHP things.
