| space2000 |
hi all,
i am now on the construction of the heat sink. it is as i told you.
it is now i am making. hulf of the way i took picture let you know how i am making. center will be quiet type mid speed fan. i have nothing so special tools available. only dril and scru driver....pencil and calculator. today probably will be finsh.
all metals are aluminium.
metal of the plate = solid aluminium
diameter of the plate = 12inch
plate thickness = 10mm
fins thickness = 0.3mm
fins height = 4 inch
fins length = 3.5inch
what do you think about heat disipraion? how many watts can put on it?
thanks for your view and comments.
spcly dear Dx.....need your comments too...as i am looking for turbo-DXxxxxx ....on it.....ha..ha...
Thank you
michael |
| space2000 |
| another picture |
| GlidingDutchman |
Wow!! That will look impressive when done!
Are you going to anodise it? I posted a rather simple procedure under "Everything Else" on how to anodise at home.
Cheers
D |
| eeka chu |
| It's not looking bad, the efficiency of those fins may be less than you might like if they're not extremely well coupled to the base. It might be worth trying to find some transparent PTC and putting a thin layer between them and the base. If the metal the fins is made out of is thin, you can also improve how well it clamps down to the base by adding a thicker strip of something like steel between the screw heads and the top of the folded bit on the fin - so it spreads the squeezing out more. |
| analog_sa |
| Will you use some thermal compound between the base and fins? In any case expect significant losses. And a lot of vibration pickup. |
| space2000 |
hi,
just finished the heat sink. yes i will put some tharmal grses under those fins to have proper contact. here is the finsihed pic...but still there are more to be done now.
all done at my home. there is no one here only me......he...he..
thank you.. |
| destroyer X |
ask the moderators to join them.
Very nice Flying Sauce heatsink.... a nice UFO (unindentified flying object)....hehehe.... i like that.
The power, in my experience, will be 446 watts.... or ... a 446 watts rms amplifier (or amplifiers), producing around 650 watts of heat, will be "controled" by your flying sauce heatsink.
How to calculate.... i have learned that observing what is good for a 10 watts power amplifier, a RMS clean power, sinusoidal power, undistorted, continuous ..... i have found an aluminium square of 10 centimeters side and 2 to 3 milimeters thick would work fine..... so..... based on that....... it is just a very easy calculation.
If 100 square centimeters can hold 10 watts amplifier... then..... XXXX square centimeters will hold (W)
regards,
Carlos |
| destroyer X |
Clean the thermal paste excess using cotton swab, clotch with petrol diluting material, alike gasoline, thinner, Kerozene, or paint remover.
Congratulations, you are having an excelent idea...you may create an excelent amplifier, one of the most pretty of this forum.
The Flying sauce power amplifier.... wonderfull idea....my deep and sincere congratulations.
regards,
Carlos |
| destroyer X |
You will make excelent advertising to the Corporation.
Will invite you to work with us..... ahahahahaha!
Corporation does not exist..... not today.
regards,
Carlos |
| destroyer X |
Using out space technology, now will have a flying sauce amplifier.
heheheh.... Great!
regards,
Carlos |
| destroyer X |
heheheh
Saudações alienígenas.
Carlos |
| destroyer X |
"We came in peace!"
salutti.
Carlos |
| destroyer X |
Have made your amplifier dear Space2000
regards,
Carlos |
| destroyer X |
regards,
Carlos |
| destroyer X |
This image has not the ionized air surrounding the space ship.
regards,
Carlos |
| roender |
| quote: | Originally posted by destroyer X
heheheh
Carlos |
Dear Carlos,
You put a big smile on my face, thank you.
You are a very good man
Mihai |
| space2000 |
Hi Dx,
Thank you, thank you for your invitation and comments. Actually I was facing problem due to arranging a good heat sink from the local market. It’s too expensive to have those are just normal and too small. 9” X 7” inch already cost me $28 to $35 each, not so good. I was thinking for it quite long time. Can’t find any good or huge heat sink in good price. I went to search for kind of Alluminium material available at local supplier. I found some I can use. I ever used thin plate squire shape but not good for heat sink as its get hot too fast, even how big I make. I touched back of the heat sink where the transistor located. I found it’s not suitable to use, too thin like 3mm sheet. I made a decision to use thick plate with flyer fins like flying souce. It will looks nice and work too. I had drawn many times to think which shape will do. I wanted to make amp as like space ship. All my own design. Material is not so expensive. Believe me or not. I only spend on it, The plate cost me only $25 + $12 fins sheet for each heat sink. Currently I bought two plates and two sheets, today just made one. Now I will make another one. If one can take two channel then will use one other wise will use two pcs heat sink.
cost for each is = $25 + $12 + scru ($ 2.70 ) = $39.70
Now I will add a fan….hvnt decide yet what type of fan will be placing into the center. I keep space for fan.
I don’t think like this heat sink will sale in the market so cheap. Also will be adding thermal pad or gum under each fins.
Transistors will be mount under the heat sink like circle shape with huge copper plate. The sink will mount on top of the amp at outside then it will looks nice.
Thanks for comments.
Best regards
Michael |
| destroyer X |
regards folks,
Carlos |
| sek |
Hi Carlos,
please remember to be careful when posting pretty pictures of your loved ones on the internet!
Sebastian. |
| destroyer X |
and please, tell me the danger about that use.
What the possible harms, the consequences, the possible bad use?... send me an E mail about please.
I have Orkut, MSN, pictures into this forum (hundreds), other foruns, Skype, Picasa and many other places... had never worried if people will make bad use... i do not care about.... i do not mind...but maybe i do not mind because there are things I do not know...please, go ahead (by mail) and give this help to your innocent forum friend.
I do not visit sex places into the internet, maybe they use our kids pictures to offer sex... fake of course...no one can make sex with a picture...also i have none psiquiatric disturb to be worried about possibilites... try to imagine if i will start to be afraid of terrorists to explode my building..there are only Christians here!
Because of that, as you may be more experienced, as you are asking me to be carefull, tell me please (by mail, direct mail) the problems we can have behaving this way.... maybe i am endangering my kids without knowledge of those things.
My daugthers are all them lovely, one more pretty than the other...i am lucky... this may be a problem....maybe
panzertoo@yahoo.com
Danke
Carlos |
| space2000 |
Hi dx,
your drawing is much more nicer then mine. i saw your picture attachment. wow your daugthers are so young. i have only two daugthers they are 7 and 5. how many children do you have? to my own view, i think best is not to post your daugther picture on the internet. though i can't find nothing could be wrong with this picture but identity should be keep safe.
i hvn't make DX-turbo circuit yet. looks like they all are incomplete so need full circuit diagram. today i will try to get full circuit diagram. may be later will go to buy some parts.
first i will try to place on one pc first.
best regards
michael |
| space2000 |
dear DX,
sorry, i just downloaded full circuit design. i only have question on D1 to D4 which type of diod i shound use. as i have seen on the picture you used diffrent type of diod. is there any part number you suggest?
thank you
michael |
| destroyer X |
image and will have explanations about...this thread is about heatsinks.... am i rigth?
1N4002 will work fine.
regards,
Carlos |
| sek |
Dear Carlos,
don't worry too much about what can happen to the picture. I was just generally speaking.
I'm writing you an email. ;)
Sebastian. |
| destroyer X |
And she have readed that to me while i was layed down, horizontally over the bed controling the blood pressure and circulation to my legs.
She asked me:
"what is the problem daddy"
I felt confused, had not good things to tell her...then i decide to return the problem to you.... i said her... ask him!
heheheh...good trick.... extinguish the fire... alike Psychological fire soldiers...changed the panic by the inquisition.
My baby was afraid of consequences.... maybe for you this expression says nothing...but i know her... this was panic!
But finished when her attention gone to produce a mail in English to you...hehehehehe.
No problem my friend... i know you have tried to help.... unfortunattely have not worked very much... Kein problem, alles gut.
regards,
Carlos |
| space2000 |
hi dx,
Don't need to be worry too much. here is my baby picure.
here she is helping me to listen the song tone....she says nice daddy.
she is now 5 years old, study at kindergarten school. her name is perry. it was my previous house which i sold then bought my this new house recently. i am Bangladeshi and my wife is chinese singaporean. the child become mixed....
** for high blood prswr you can eat celery (vegetable). it will bring down your prswer level. i ate last time and now i don't have any blood prswr at all. i do regular exrsize.
best regards
michael |
| space2000 |
hi dx,
now she is now 5 years old study at kindergarten school. her name is perry. it was my previous house which i sold then bought my this new house recently. i am Bangladeshi and my wife is chinese singaporean. the child become mixed....
best regards
michael |
| space2000 |
hi dx,
best regards
michael |
| sek |
| Sim claro, tudo bem. :) |
| destroyer X |
Mine is always with me... alike a dog.... the place i go, there she is with me.
We love one each other a lot.
Tudo bem.
regards,
Carlos |
| space2000 |
yes...its working fine. when i used compound under the fines fins showing the sign of heat. good..i will check even more farther. will takes time..
now assembling all....
thanks |
| Buzzy |
WOW ! space2000 its so well made. Very professional. The fan is so tiny compared to your monster heatsink . HaHa.
Btw where did you get the aluminium ? I have been looking for aluminium and can't seem to find it. |
| artquake |
space2000,
looks good ... the lamellas of your heatsink are most inefficient when regarding at the total amount of dissapation area for heat transfer ... in that point of view only the aluminium baseplate is active and the lamellas are acting primarily as a air guide (in fact of laminar air flow) When using a fan then they are useless ... you must attach them friction-fitted on the contact area for maximum heat conductance ...
Air is a very good isolator ... and the other thing by view of heat conductance is to know if your fan blows or sucks the air, that can make also a big difference ...
just my two cents ;) |
| space2000 |
hi,
i attached those fins well with heat compound under each of them. it has a fantastic result on heat disp.
here is the pic.... |
| destroyer X |
to my E mail adress please.
It is needed into Orkut
regards
Carlos |
| space2000 |
hi,
I was having problem with the Dx-turbo Box making, since i had attached the circuit onto the heat sink so i made a box today. new looks for Dx-turbo amp. i posted two picture...one when i was making and another is just finished.
best regards
michael |
| space2000 |
| another picture |
