diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Ultrasimple MM/MC RIAA Preamp mkIII - Click HERE for Original Thread
GlidingDutchman
A friend of mine (Ludo) tweaked the circuit by Mads K.
I a having trouble getting it to work so I thought I post it here for some discussion.
peranders
Have you checked the working points for all three JFET's? Are the JFET's capable of 12 mA Id?
GlidingDutchman
quote:
20mA max...
D
Conrad Hoffman
You're at the mercy of whatever current flows with the gates grounded (Idss?, I forget), and this can vary. You might have to adjust the upper three resistors to get the voltage drop you want. Other than that, it looks like it should work fine. I assume the gain is rather low and another gain stage has to follow this.
GlidingDutchman
quote:
I guess so...
Conrad - this design stems from here: http://www.diyaudio.com/forums/show...&postid=1550522
and the unit, as designed by Mads K works just fine as it stands with my Kiseiki Purpleheart Sapphire low output MC cartridge...!
D
tschrama
If you really want to optimize the circuit, read the optimum Voltage supply idea of Nelson in:
http://www.diyaudio.com/forums/show...988#post1552988
and posts before there...
Page generated in 0.022640943527222 seconds with 17 queries,
spending 0.00692368 doing MySQL queries and 0.01571727 doing PHP things.
