diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
Is there a TQWP design for the FR125SR? - Click HERE for Original Thread
Special Ed
As I sit here, I'm listening to my first pair of homemade speakers. They are the old Weems pipes with 40-1354s, and I love them dearly. I'm wanting to make something similar with better drivers, and the FR125SR look really interesting. Has anyone modeled them in a TQWP? Or built some? The spec sheet on the CSS website mentions a bunch of designs, but I couldn't find any of them.
Thanks!
Cal Weldon
One of the best implementations I have heard is the Calhoun from Scottmoose and planet10. It's a big box but an easy build. The side mounting of the second driver is a big plus. It's about halfway down the page.
You can see it here on Dave's site:
http://www.frugal-horn.com/spawn-plans.html
gurley123
There's also a Bi-pole TQWP for these on the Planet 10 page but they are pretty big also. looks kinda cool though.
Here's the link
GM
FWIW I made an adapter to mount the original version of this driver into some existing 40-1354 MLTLs with excellent results, though I did finally tune them a bit lower to take advantage of its prodigious Xmax, so I imagine you can get similar results from your existing Weems pipe with possibly only some stuffing adjustment.
GM
Special Ed
I want to make an entirely new speaker. I was considering using Bob Brines' version of the ML TQWT for the 40-1354. Would this be a good starting point? It seems his version is much more refined than the Weems pipe.
GM
It appears to be a bit too large, but damping will take care of that if required and of course you'll need some BSC if well away from any boundaries.
Note that this driver has no rising rate suspension to protect it against bottoming like the 1354 does, though I found my pair to be very robust with no audible problems after numerous 'clanks' playing PF's DSOTM and Jimmy Smith's 'ROUND MIDNIGHT at levels loud enough to bring the apartment neighbors over to be amazed at how loud/clear these small drivers play. ;)
GM
planet10
quote:
Here's the link
Just halve the cross-section. Fold it to make it shorter....
Cal's boxes are the best i've heard with this driver.
dave
Special Ed
quote:
dave
Which boxes are those?
Cal Weldon
post #2
http://www.diyaudio.com/forums/show...148#post1552148
Special Ed
quote:
Originally posted by Cal Weldon
post #2
D'oh!
Thanks!
Special Ed
Dave,
I really like the looks and reviews of those miniOnkens.
Might have to change my mind about wanting a new pair of pipes.
tubesguy
SpecEd -
Might be able to help you out. PM me if you're interested in a Dave and Chris built, unfinished pair. TIA - Pat
chrisb
dave
quote:
Remember that Cal's boxes have 2 drivers per cabinet, with the second one on the side of "chamber", mirror imaged to provide tons of placement flexibility and tailoring of soundstage to the room - don't be tempted to mount both on the front.
FWIW, the mini-onken* (FR125) is a great performer in a little box, but the by the time you consider required stands, the footprint is about the same as any of the SPAWN family, and I'd concur that the Calhouns are the best implementation of unassisted FR125's I've yet heard.
*the Fostex version of this design, particularly with fully EnABLed drivers is a different class altogether - they won't rock out like the FR125's, but certainly excel in other areas.
LineArray
This design works very well ...
It is a Prototype only, port will have to be
integrated into the enclosure.
LineArray
rear firing driver and port:
Page generated in 0.037487030029297 seconds with 17 queries,
spending 0.00789809 doing MySQL queries and 0.02958894 doing PHP things.
