diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Aikido preamp muting - Click HERE for Original Thread
dine1967
This is my first tube project. I have a working aikido 24v version with 6gm8 tubes. I have used Broskie's pcb. I wish to mute the outputs during power on. Is it fine to short the outputs like one does in SS preamps?
thanks,
Dinesh
woodturner-fran
Yes,
I've done it with no bad effects - you could also go for something like the e12 delay from amb.org...
Fran
dine1967
Fran,
Just to clarify, you short the outputs to ground during power up. I saw the e12 and it passes the signal through the relays instead of shorting them.
thanks
Page generated in 0.017528057098389 seconds with 16 queries,
spending 0.00839686 doing MySQL queries and 0.00913119 doing PHP things.
