diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Dr. Imbabi’s DIY Power Supply? - Click HERE for Original Thread
GlidingDutchman
Hi there
I searched all over for a link to this PSU and the only one I found here is a dud!
Anybody have the schematic or a live link to it?
I am looking into building a similar PSU but would like to check it out.
It is for a Lenco L75 turntable (with a shaded pole motor)
T-I-A
D
cromodora
I have a copy of his design for the Gerrard 401.
PM me your email address.
I too have a L75 and would be interested in your build.
GlidingDutchman
Cromodora - you've got mail... :)
What do you think of this?
http://www.norre.dk/TTPSU/TTPSU.html#Downloads|outline
D
kevinkr
D
Interesting design, one concern is the issue with distortion of the output sine, I am not sure whether that is actually an issue or not, but I would probably replace the first order LPF with a 2nd or 3rd order filter if I were concerned.
GlidingDutchman
quote:
Hi Kevin
Distortion is not really an issue here - as long as the output signal is an appoximate sine wave with a stable frequency.
I wonder if there is simpler crystal oscillator diagrams somewhere without a complicated PIC and display...
D
analog_sa
Distortion is most definitely an issue but this approach delivers reasonably low distortion. A few years ago i did a very similar exercise using a 90S8515 and measured a second and third harmonic within 0.1%, pretty much on par with a good Wien bridge. I used a proper 8-bit dac but accurate resistors are probably fine. Reshaping a square wave is not likely to produce similarly low distortion.
A Wien bridge is certainly a great 5-minute solution, perfect if you don't need fine tuning or two phases.
GlidingDutchman
Ja - an issue but not that big an issue... you're not going to pump music throught the thing... he-he!
Man - I am looking for a single phase VFO that enables you to set two seperate freqs for 33.3 and 45 rpm but still allow fine tuning of about +/-20%. Two fine tune pots plus a toggle-sw between the speeds. Thats all - no need for a display... one can check the speed with a strobe on the platter.
Wien-bridge is allright but isnt there a "digital" solution? Will certainly be the only digital in my analogue front-end - he-he!
D
analog_sa
D
The way i see it the main point of aftermarket AC power supplies is the low distortion. At least in synchronous motors it obviously affects the vibration of the motor and the sound. Even with a Garrard induction motor i hear obvious difference in sound depending upon the oscillator quality. But then again i also clearly hear the mains cable to the motor...
A simple digital solution (no micros) won't have easy trimpots. And it will definitely generate a lot of RF noise which will have to be filtered or else will mess with the rest of your system. A micro is the easiest way, especially if you are just repeating an existing design. Even easier is to buy one of Mark Kelly's boards and just solder the parts. I hear they are excellent.
A Wien bridge can do all that you require. Why complicate things?
GlidingDutchman
Vra ek ook - ask I also... :clown:
These thingys could be an option? >> http://www.maxim-ic.com/appnotes.cfm/an_pk/3846
D
analog_sa
A great idea. No experience with these particular pots but they seem quite simple to implement. Even simpler is the DS1802 - you just need two pushbuttons. In any case it's a much better solution than ordinary pots.
Jaimo
I am considering the following solution for my Garrard 301 psu.
1. Generate a 30 minute 50Hz wav file using Audacity. (16 bit 44.1kHz, about 2.5MB)
2. Load the wav file into a $20 mp3 player.
3. Use the MP3 player output to drive an old Rotel RB990bx power amp.
4. Take the output from the Rotel into a step up transformer.
The MP3 volume control will adjust the output voltage and it is possible to create other wav files to do a speed change.
This looks like simplicity itself! (Almost too good to be true) My only concern id that the input resistance of the transformer is about .5 ohms and will most likely cause the Rotel to blow it's fuses. I plan on adding a series resistance to the transformer input and will fire this up tonight.
Any comments before I smoke the Rotel?
Else I will report back tomorrow
Wat se jy Mnr Flying Dutchman?
Mark Kelly
You'll probably need a linear pot on the output of the MP3 player, the internal digital volume control is a bit crude to get the voltage dialled in.
You will also need to add a Zobel to the output of the amp. Try 10 ohms / 47 uF as a starting point.
If you use a T amp instead of the Rotel you can get away without the Zobel.
Toroidal step-ups appear to have far less problems than EI laminations, probably due to the lower magnetisation currents.
Jaimo
Thanks for the t-amp tip Mark.
The Rotel amp works for about 20 mins & runs extremely hot before it's protection steps in.
I took a look around and can't find a T-amp that will give me the required 20Watts - whick T-amp are you using?
nicoch46
41hz.com ;)
Page generated in 0.043342113494873 seconds with 17 queries,
spending 0.00809646 doing MySQL queries and 0.03524566 doing PHP things.
Please support our sponsor.
