diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Kenwood and Telefunken turntables for newbie - Click HERE for Original Thread
Erik1
Hello!
After some time as a Hi Fi fanatic, I have recently taken an interest in turntables. This week I came across a couple of turntables that haven't been used for some time:
Kenwood kd-2055 (Resin base, "Marble")
Telefunken s 90 cx
They are both spinning the disc, but the cartridge on the Telefunken is gone and the Kenwood cartridge needs to be changed.
I have read that some use Ortofon OM10 or Shure V41 for the Kenwood. Would any of you recommend these?
How can I tell the difference between the standards 1/2" and T4p on the tonearm? Any information regarding the tonearms?
To me, it seems like the Kenwood was expensive when it was released, but I have my doubts regarding the Telefunken. Any comments from those of you who know more about turntables than me?
Any information/comments on the turntables will be appreciated.
Best regards
Erik1 :D
Nanook
well the 1/2" mount has two holes in the top of the cartridge, centred at, you guessed it, 1/2" (or about 13mm),
The "P" mount pushes into the tonearm and is secured by a screw from the side of a cartridge.
look here
for a quick picture...
I have an Ortofon OM10 mounted on a "Kencraft" (by Trio/ Kenwood) and it makes some nice sounds. The cool thing with the OM10 is that you can upgrade to a better stylus if you feel the need without having to change cartridges.
If the Telefunken is typical plastic, then yes, the Kenwood is a much better table.
Erik1
Thanks for your answer. The link was really helpful!
Erik1
Page generated in 0.022474050521851 seconds with 17 queries,
spending 0.00928020 doing MySQL queries and 0.01319385 doing PHP things.
Please support our sponsor.
