diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
cardas grmo - help appreciated - Click HERE for Original Thread
mikey115
hello, how do i use this rca plug when it comes to connecting the ground? there are no tabs for this and i only see a bridge about 2/3 from the base of the plug as something that the ground was meant to be connected to. would this be right? i would prefer a secure mechanical connection instead of merely soldering to the inside of the inner barrel but any insight on what is the best way to work with this plug or how it was intended to be used by cardas would be very much appreciated. thanks.
rgds
mikey
Page generated in 0.017831087112427 seconds with 16 queries,
spending 0.00927949 doing MySQL queries and 0.00855160 doing PHP things.
