diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
FS: 8 x GR Research M-165X XBL^2 Drivers - Click HERE for Original Thread
gitarretyp
I've had these for a couple of months and used them in this project , where they worked extremely well as mid-basses in a shallow u-frame. They are all essentially like new.
Specs can be found here and are as follows:
FS 40 Hz
RE 5.6 ohms
Qms 2.73
Qts .44
Qes .526
Xmax 7.8 mm each way
L (1k) .86 mH
L (10k) .36 mH
Vas 34.57Liters
Ms 11.9 grams
Cms 1.3183 mm/newt
Bl 5.66 Tesla-M
SPL 88.3 db
Area 137.7 sq cm
Asking $30/each
chrismercurio
What are you building now?
ttan98
FS 40 Hz
RE 5.6 ohms
Qms 2.73
Qts .44
Qes .526
L (1k) .86 mH
L (10k) .36 mH
Vas 34.57Liters
Ms 11.9 grams
Cms 1.3183 mm/newt
Bl 5.66 Tesla-M
SPL 88.3 db
Area 137.7 sq cm
Asking $30/each
Seen you at Open Baffle, just curious if it works well why you are selling them?
gitarretyp
I got the okay from my significant other to build something bigger in lieu of having subs. So, i'm now running two AE IB15 open baffles per side from 20-200 Hz. I was only using the GRs from 75-225 Hz, where they work very well.
gitarretyp
Bump and reduced to $25 / each
gitarretyp
Six still available
Page generated in 0.026279926300049 seconds with 17 queries,
spending 0.00815964 doing MySQL queries and 0.01812029 doing PHP things.
Please support our sponsor.
