diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
hi-end Line filter - Click HERE for Original Thread
umut1001
hi everybody..we want to make a hi-end diy line filter for tube amps and general purpose amps..we want no dc humm,hiss and buzz..here in our country electricty is 50hz and sometimes dirty..and also i dont want to hear any cracking sound from speaker when turning on and off the lights..i have a schematic..i did this pi filter but there is still a sound when turning on my drill :) does anyone know about this subject ?thanks a lot
umut1001
hi there..does anyone have an idea about it ? we need help
AndrewT
that circuit is visually balanced but in reality is not balanced.
The safety of having the blocking caps in both Live and Neutral lines is reduced compared to having all the blocking in either the Live line or in the Neutral line.
It is better to have interference suppression fitted at source than to apply filters at the inputs to your equipment.
Ensure all you domestic equipment is properly suppressed.
umut1001
hi andrew..thanks for your help..and i wanna ask something again..there is several mkps here in shops..
philips mkp X2 100n
arcatronics 100n
roederstein 100n
hitano 100n
i dont know about these capacitors..also i had wima mks but i think its not reliable for audio..which one should i buy ?or can you advice another one?it must be hi-end filter for expensive tube amps..
thanks a lot
richie00boy
The capacitors across live and neutral must be X or Y rated. This circuit is nothing to do with audio as it's connected to the power supply, the mains at that, so ignore audio caps.
AndrewT
quote:
Originally posted by umut1001
philips mkp X2 100n
the philips X2 is rated for connection between Live and Neutral.
Do not use anything that is not rated for mains use.
Must be X rated for Live to Neutral.
Must be Y rated for Line (Live and/or Neutral) to Earth.
umut1001
should i also connect one more 100n capacitor between live to earth(not neutral) ? like this picture
AndrewT
depends on what earth leakage you or your system can tolerate.
It is better to use two Yrated caps, one from Live to Earth and the other from Neutral to Earth.
jacco vermeulen
www.ibselectronics.com/pdf/pa/wima/..._capacitors.pdf
umut1001
hi..sorry but i dont know what is X and Y rated capacitors..is it a specification ? there is not wima Y capacitors here in my country
richie00boy
In EU countries you cannot connect 100n to earth like that, usually 4.7nF is the most you can allow.
I'm sure X and Y rated caps must be available in Turkey, they are very common indeed and mandated for mains use in all EU countries. Don't restrict yourself to Wima, although I have a feeling I have some Wima X2 rated caps somewhere.
Page generated in 0.028358936309814 seconds with 17 queries,
spending 0.00799012 doing MySQL queries and 0.02036881 doing PHP things.
