diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
essential to use a power factor corrector - Click HERE for Original Thread
jegandren
Hi all,
i would like to seek advise, is it essential to use a PFC to convert AC to DC to supply to my DC-DC half-bridge SMPS. or can i just straight away convert from AC-DC from the mains and supply to the DC-DC half-bridge SMPS. Please advise.
Bootstrapper
Hi, power factor correction is not necessarily required - you can design a fully operational ac-dc -converter without pfc. The thing is, pfc is required after your converter exceeds certain power level. This way the line current distortion is kept at acceptable level.
What I am trying to say is that you don't have to use pfc, unless you are about to build thousands of converters for selling. Although pfc circuits are quite simple, so if you have a functional half-bridge converter, you should be able to design a pfc circuit, too. After all, a pfc circuit is just a boost converter.
Page generated in 0.022541046142578 seconds with 16 queries,
spending 0.01089382 doing MySQL queries and 0.01164722 doing PHP things.
