diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
which aleph class A sound is good? - Click HERE for Original Thread
space2000
hi,
which version of aleph class A amp sound is good, sweet and tight bass?
thank you
mcihael
otto88
I haven't had the opportunity to compare, yet :(
But I recall it's been written here that the Pass amp designs have become more 'romantic' & less analytical over time, from eg the A40, 1978) to later Alephs.
Have 2nd harmonics increased??
Again I may be wrong, but does the X variation of Aleph add dynamics?
For a more specific answer, it may be helpful to say:
what power level into what load, over what frequency range, what priorities - would you use it?
If I can add a parallel question: :)
I’ve been thinking of making a Pass, solely to drive the ribbons in Apogee hybrids, with an active crossover.
With only c 85 dB/ watt/ 1 m, about 60-120 watts into 4 ohms, min 600 Hz ( . . bass irrelevant), min 3.1 ohms @ 2500 Hz, priority is “clean highish Hz detail”.
Suggestions for this particular application appreciated!
dw8083
Hi Michael,
All the Alephs are good in this regard. The other components in your system will have a bigger impact than the specific model of Aleph. The sonic variances between the models is a matter of personal taste.
In another thread, I think I recommended the Aleph30 as a good place to start. The Aleph30 or 60 is famous for it's clean clear bass and sweetness in the upper ranges. In the day, most of the magazine reviewers stated the Aleph had the authority of solid state and the sweetness of tubes. I have to agree that the Aleph has the best characteristics of both.
The bass is very clear. Rather than hearing a bump or thump in the bass region as with my $1000 Rotel 990bx, you now hear the individual bass instruments layered in their individual octaves - Absolutely a fantastic soundstage with lots of air around each instrument.
The Aleph 30 executes absolute authority over the speakers.
The Aleph is not very hard to build either for a new hobbyist.
-David
otto88
I googled and the Aleph 30 into 4 ohms, does 45 w. What is your load?
With my 85 dB drivers, 45 watts at my listening distance would yield about peaks of 99 dB, on some music just a bit tad light on. What’s the next level up in Pass power?
dw8083
Hi Otto88,
The Aleph will scale up to almost anything you like. Pass Labs sold the Aleph with 30, 60, and 100watt ratings into 8 ohms. The only real key difference is the number of output devices, bias setting, and rail voltage.
Take a look around the forum here, a lot of people have built Aleph 2's at 100 watts and Aleph 60 or Aleph 5's at 60 watts.
Used Aleph 5's sell for about $1400 on Audiogon.com
-David
otto88
I have so many diy speaker projects in line, it’d take me ages to get to building an Aleph, so buying is more sensible.
But I’m in Australia and most Alephs weigh over our postal limit of 44 lbs, so with couriers become very expensive to ship to here . .
However I’d guess that each Aleph 60 mono would be under that limit.
Seems the 60 was only made for a brief period, do they come up often?
If not, how much do Aleph 2’s go for?
dw8083
The Aleph 2 mono blocks sells for about $2200 here in the US. They are extremely heavy.
Try the Aleph30, you maybe surprised how much punch they have. Class A seems more powerful for it's given rating than class AB amps. I'm driving a pair of Magnepan 1.6QR's without issue. The Magne's are 89spl at 4 ohms.
You could bi-amp with a pair of Aleph30's if you need more power.
-David
macka
Depends on the impediance you want to drive.
None of the Aleph have the dynamic qualities of the X series but the best of the bunch is the Aleph 2.
You might look at the F 5 if you want tight bass and something tht is easy to build,
iMac
Nelson Pass
I have always favored the Aleph 2 as the most neutral of the bunch.
Page generated in 0.031471967697144 seconds with 17 queries,
spending 0.00978827 doing MySQL queries and 0.02168369 doing PHP things.
