diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
question about Aleph-3 , need help - Click HERE for Original Thread
space2000
hi,
i just made aleph-3 its working fine as far i can see. i want to ask few questions about the voltage.
its says 25vdc + - but i applied 29v+- as i had the transformer. should it be any problem with bit higher voltage?
as my main voltage is 29vdc + - . i used two pair mosfets insted of 3 pair at output just for testing purpose. when i checked the main voltage, i have found it's drop to 27v. if i add more its drop bit more voltage. is it normal in class A to drop some voltage like this or my amp have some problem?
my heat sink temperature count after run 20mints rum 41c. our room temperature is 30c.
anyone can help me pls as i am new to class A amp.
thank you
michael
dw8083
You can run the amp at 29vdc, if you have adequate heat sinking or adjust the bias. If needed, place additional resistance in the CRC portion of your power supply to drop the voltage a bit.
Also be sure to check the heat after 1 hour and every 30 minutes. The amp will get a lot hotter as it runs.
The rule of thumb is not to exceed 50c, or the output devices will be short lived. In a commercial set-up the temp sould be lower than this for trouble free longevity. My Aleph runs just below 50c after 2-3 hours with 28c ambient temp.
Search the forum, since there has been TONs written on tis topic.
-David
space2000
hi,
i want to know is this very common in dropping voltage as adding more output mosfets?
like mine two pair of mosfets drip main voltage 29 to 27v.
thanks
dw8083
The original Aleph 3 had 4 output devices and the Aleph30 had 6 both per each stereo channel. Perhaps this will provide some benchmark. Look around the forum for A30 schematics to see the idea. The notion of paralleling more output devices is to distribute the load for reducing the stress of the output devices.
Also toss in some 3w or 5w resistors in parallel, in the "R" section of the CRC power supply, to drop some volts as needed.
Paralleling the resistors better dispates the heat.
-David
space2000
hi dw8083 ,
i couldn't understand this. what is CRC?
my original voltage is 29 after connect the amp is now drop to 27, there is 2v short so the transformer gets hot.
thank you for helping,
dw8083
After the rectifier in the power supply, the Aleph has a large capacitor, followed by resistor(s), followed by another large capacitor to smooth out the ripple in the unregulated DC output. Thus the designation CRC - Capacitor, Resistor, Capacitor.
The greater the resistance the greater the voltage drop.
Attached is a circuit diagram from Duncan Tools PSU simulator. It's worth Google-ing it up for experimentation. I found it to be pretty accurate and a great learning tool.
What is the VA rating of the transformer? It does tend to get hot.
-David
space2000
hi,
thank for info. i thought related to the circuit problem. ok i will add few 3ohms 3w resister to the power. my transformer is 10ampire.
best regards
michael
dw8083
Michael,
Download the Duncan's PSUD2 power supply simulator.
http://www.duncanamps.com/psud2/index.html
If memory serves me, the Aleph 3 draws something like 2.5amps of current per channel.
It will help you find the right values for the resistors. Here's a link to a parallel resistor calculator: http://www.1728.com/resistrs.htm
Once you find the right resistor, duplicate that value through the calaculator above for 5 or 6 3-5w resistors in parallel to share the load.
-David
space2000
hi,
now my psu is working fine. slightly voltage drop. every things is working fine. i have little bit hum, i know its require a air coil at power supply. how can i make my own? or can use others things?
second question is, i want to adjust output voltage(bias). now it is showing 0.330v at output. is it too low or i have to adjust higher?
how can i adjust higher?
my amp is 30w RMS.
thank you.
michael
dw8083
Perhaps you could post the exact schematic and parts used.
-David
space2000
hi thanks for help.
here is the circuit. i followed same as it is. power supply is 29vdc.
space2000
hi,
can i add more then three pair of output mosfets? as it is only 30w using three pair of mosfets. if i want to get 100w then i will require 7 more pair. also the power supply must be 0.5 X 20 =10 ampaire.
thank you.
dw8083
As you increase voltage and current, the power output will increase. It is necessary to add additional Mosfets to dissipate the increased power levels across more Mosfets as to not overload those output devices.
On your other question... When measuring the output voltage apply a sine wave of a known voltage and measure it's amplitude at the output. You will need a signal generator and a scope. A simple singal generator can be made pretty easily.
Perhaps other forum members here have a better idea, but that's how I've done it.
-David
Page generated in 0.032936096191406 seconds with 17 queries,
spending 0.00665045 doing MySQL queries and 0.02628565 doing PHP things.
