| icecoolwas |
Hey i need a sub that sounds good at 20 watt rms @ 4ohm
Why you might ask? why 20 watt rms? i have a 4" logitech system and its blown, but the amp works, ive got a infinity 12" connected, its loud but 20 watts does not push it. im looking for something like a 8" that will Bump from 20 watts.
Thanks |
| Thawach |
icecoolwas i think that it's difficult to find the driver. 20 watt is difficult to bump the 8" driver. but it can be if u looking for the 8" about 30watts. i remember when i am a super baby,i had ever done. it worked.
regards
TW |
| icecoolwas |
| hmm k.. I remember like ten years ago they used to have 18" subwoofers running off 150 watt rms Pounding, im looking for something thats old (thus needs less power) but smaller (around the 10" size?) and cheaper. |
| saabracer23 |
Just look for something with a high effeciency, it doesn't need to be old. Since there is probably nothing going too low (since you were using a 4" driver) I would go for a pro driver, something with a mid 90 db at 1 watt/1 meter.
Dan |
| nigelwright7557 |
| quote: | Originally posted by icecoolwas
I havent seen an 18 inch driver that is that low in watts.
I use a Fane Collossus 18 inch driver that is 600WRMS.
I put it in a folded horn cabinet and it really thumps even on moderate powers. |
