diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
my first step to class A amp -aleph3 3ow. - Click HERE for Original Thread
space2000
Hi all,
Today I just tried to make Aleph3 30w class A. once I build the circuit, it is working at the first step trial without any error. But some things I don’t really understand about “R8” and “R115”. Though I used pot but I need to clear this. Pls any one can help me?
Now my amp heat is about to 44c. its looks nice temp.
Need suggestion pls.
Thanks for help.
Zen Mod
quote:
Originally posted by space2000
Hi all,
Thanks for help.
exact schematic please ;
accidentally - I erased all resistor numbers in mine schematics of A30 ......
:clown:
maybe attached file will help you - look at notes ( by courtesy of Algar_emi )
space2000
hi,
thanks you posted pdf file. yes this is the one i am building. mind led don't have any light, why is that for?
anyway can i put pot on R8 and R115, which value should be just nice for this circuit?
thank you.
Zen Mod
hi,
thank you.
led - you probably reversed it ( most often mistake ;) )
R8 -- you can try without it , for start ; report what DC offsets on outputs are , so we'll know do you need them ;
R115 - leave it as is for start (820E ) , and later - when you learn few things , you can measure AC gain of output CCS ( upper output mosfets ) , and you'll know what to do .
space2000
thanks for help....now i am listing . led i tried to reversed but still no light.....
Zen Mod
:D
replace the led .......
space2000
just check Dc output voltage is 0.226....what is the value should be there?
space2000
i want to know. as i have seen on aleph3 has used three pair of IRFP240. here per pair is 12.5 watts output so total is 36+ watts....can i add more output mosfets following the output rail?
i know there must be increase more power supply amp.
thank you.
mciahel
ttan98
You have so many amps where do you put them?
space2000
quote:
Good question.
actually i am learning by making many types of amp as i can. it is my hobby. i just make my own and keep as well. my friend took two to listen. one i make for my uncle he is very happy. i never took any extra money for workmenship or anythings at all. they will return me when they can....only to my uncle, i gave him as a present.
thanks for asking...
skizz99
Regarding the LED
The 100k of RD in the schematic looks very high to me. The value should be more in the 1k to 2k range.
A LED needs current to send out light. This current is usually defined as If (forward current) and can be looked after in the datasheet. This current is usually in the range of 20mA.
With simple math and knowing that there is a voltage grop of 4 Volts on the LED (for a blue LED, yes it is Pass Labs) or 2.5 Volts for green, you can calculate:
R = (V_supply - V_LED) / If
R = (26V - 4V) / 20mA = 1100 Ohms
If you change RD from 100k to 1.5k the LED should be transmitting light.
space2000
quote:
Originally posted by skizz99
Regarding the LED
hi,
thanks for help.....
i had posted into wrong place so now i am posting here.
at first i just tried with one pair of IRFP240. heat sink heat was only 44c round . when i added another two more pair mosfet. wow, heat was nearly 60c. sound quality was great, clean too. instruments sound was very nice and sweet. i was listing quite long time. anyway i know its need very big heat sink.
i want to know, which sound is btr, mosfet or valve class A amp?
thank you
Page generated in 0.043826103210449 seconds with 17 queries,
spending 0.00955391 doing MySQL queries and 0.03427219 doing PHP things.
