diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
13,8v 100Ah. - Click HERE for Original Thread
foxeletronic
Hello friends, I need an outline of source chauvinists with entrance of 220 volts, exit of 13,8 volts and 100 Ah of current. If somebody has, at once I thank.
Email: foxeletronic@ibest.com.br
:smash:
luka
Hi
Output of 100Ah is simple, use 1A 13.8v for 100h and you will have what you want:D
S.G. Mahbub
foxelectronic,
In the context of Modern Power Electronics, your requirement is not a difficult one. If you are serious, it can be done.
Your requirement is 13.8 v and 100A , that is 1380VA. Your input voltage is 220V. So, you require approx. 7A from input source. Very simple circuit.
You can do it with IGBT Module and discreet IC. But I will advocate you to go through Microcontroller route and then you will find it is so easy and interesting.
Modern Power Electronics Technology incorporating Microcontroller Controlled Process made things possible which was earlier impossible.
If you are serious, I can help you.
foxeletronic
Thank you very much for assisting me, I am wanting to set up that source, but I don't know them you formulate to calculate the transformer for the source chaveada. She can help at once I thank. Fort hug.
Excuse my English it is with translation, through software (globalink).
jtkraj
I think, for better efficiency and if you are not particular about the isolation, you can for a buck converter. You can improve on the input power drawn. This is an easily achievable target.
When you say 100Ah. Is that Amp/Hour??? I am a bit confused. This term is not used for an AC/DC converter. This is used only for only for battery-powered supplies.
walkura
@Luka .
You forget about the Peukert factor .
With such a low power consumption like 1 Ampere your 100 Ah battery will actualy last maybe even up to 150 hours .
@foxelectronic.
With a conventional transformer it will be heavy and when you use thyristors for rectifying you could even regulate the current .
The minus is that it will be a very big and heavy machine .
Last week i builded a charger like that and its 25 kilo easy (thats without elko's or finer regulation)
luka
Hi
It is by definition :rolleyes:
And 25kg? where did you get that? it can be smap you know...
walkura
You know how those oldtimers (like me) are .
Conventional transformers of 2500 or 3000 VA or if needed 3 of them in 3 phase .
Robust very straightforward and unless mistreated very bad virtualy indestructable .
S.G. Mahbub
Yes, old method of linear mode power supply is very reliable with less or no emi or rfi and virtually indestructible but for high power one, weight would be enormous and cost will be huge.
Consider about the one walkura mentioned- about 25 kg. That's why smps comes and with switch mode, the weight will be maximum 2-4 kg.
Now a days, high power dc to dc conversion is made through controller controlled chopping and rectification method. Using Ferrite Transformer for high power is also used but efficient heat dissipation system for the heat generated within the wire turns and core has to be incorporated in that system which is a real problem for the durability of the high power system.
Thanks.
Stupidity is the funny and purposeless action of some human beings- nothing to do with God or Heaven.-------- Chinese Proverb.
foxeletronic
Somebody has her it formulates of I calculate to calculate the transformer toroidal for the source chaveada (smps). Thank you.
CHACALPOWERS
Hi Brazilian Brother
In the WWW.THORNTON.COM.BR there is instructions to calculate your toroidal transfomer.
(a moçada não gosta que a gente escreva em outra língua mas isso não é problema nosso)
Abraço
CHACALPOWERS
Page generated in 0.0296630859375 seconds with 17 queries,
spending 0.00788522 doing MySQL queries and 0.02177787 doing PHP things.
