| UC 3846 current mode control IC help - Click HERE for Original Thread |
| jegandren |
hi,
im just studying on using UC 3846 as my SMPS control ic... i have tried conecting an open loop test circuit....but the it looks like there is no output pulse given to drive the switch of the trasistor...is there anyway to test the UC3846 current control IC. newbie here please help!!!
(any replies regarding this would be appreciated) |
| jtkraj |
These devices are Current controlled. you have to provide a Current sense resistor and fead back circuit.
Each cycle have to be controlled through these signals.
check you have configured the comp signal properly. |
| switchmodepower |
Make sure that the comp pin is high, shutdown is low, make sure CL pin is set. You can also add a slope comp circuit to get some sort of ramp on the curr feedback pin- (this also helps with noise immunity)
App note..
http://www.ti.com/litv/pdf/slua075 |
