diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
Charlize/Trends TA10 modded + USB DAC or Nuforce icon - Click HERE for Original Thread
Rafoo
Hello everyone, I'm planning to get an amp for my room (9m²) using my laptop as a jukebox with an USB DAC.
I've got different options :
-To build a charlize amp with a USB dac in the same case
-To buy a trends ta10 (modded or not) and a superpro dac with usb
-To buy a nuforce icon.
About the charlize, I think the price will be higher than with the other options becaus I have to buy the case, connectors etc.
About the trends, I've found 2 modded versions, the first one is the mardis V3 here http://www.audio-magus.com/ProductD...ductCode=TA10M3
and the modded version from ndi http://www.ndi-france.com/article.php?articleID=184 with caps changed for BlackGate FKs and ModWright Teflons. Which one is the best mod ? maybe a combinaison of both.
I can also tweak it myself, but I have to know how.
And finaly about the nuforce, it is the cheapest option, but with a class d amp, a nice finish and a usb dac integrated.
All I want to know is wich one will sound best, and at what costs if I have to tweak them. I read that a stock charlize can rivalize with a tweaked trends, but what about the nuforce ?
dweekie
I had a Nuforce and quite a few tripath amps. The Nuforce is alright, but a tweaked tripath amp will beat it. The DAC portion is just the basic PCM270x circuit with big electrolytic output caps. A Charlize and Monica could work for you as an all in one solution if you want to build up your own enclosure. The Monica should be quite a bit better than both the Superdac and the Nuforce dacs.
Rafoo
Ok then I think I'll go for the charlize. But the monica dac is quite expensive compared to this
http://cgi.ebay.fr/ws/eBayISAPI.dll...em=140239887484
with this for the usb connection
http://cgi.ebay.fr/ws/eBayISAPI.dll...em=180252440478
I read that this dac s using a really good chip but with cheap caps etc that can easily be replaced by better ones. What do you think about that ?
dweekie
There was a very detailed mod thread on that dac somewhere, I think on pink fish media forums. I'll link it if I can find it again. People seemed to like it on the thread. I have no personal experience with it.
dweekie
quote:
This seems like it.
http://www.pinkfishmedia.net/forum/...ead.php?t=42848
Rafoo
Thank you very much Dweekie !
Rafoo
I got a question about charlize's PSU.
I've got 2 solutions : to use this PSU :
http://www.autocostruire.com/catalo...products_id=264
It has an output at 13,7V the exact voltage needed for best perf on a t2020 amp. but it is 50 euros and I need to add a 30 euros rcore transformer.
On the other hand I can buy an smps psu (I heard many good things about this kind of psu) like this one :
http://cgi.ebay.fr/ws/eBayISAPI.dll...em=350067999934
Look at the price ! It is 12V but isn't it tweakable ?
Nanook
check here
(Audiomagnus..)
stew
Rafoo
I've found various smps supply on ebay
http://cgi.ebay.fr/60W-12V-5A-Switc...1QQcmdZViewItem
http://cgi.ebay.fr/DC-12V-5A-Switch...1QQcmdZViewItem
http://cgi.ebay.fr/ws/eBayISAPI.dll...em=350072678475
http://cgi.ebay.fr/ws/eBayISAPI.dll...em=190219256068
http://cgi.ebay.fr/SMPS-8080-12-vol...VQQcmdZViewItem
Is there a chance they can be good for the charlize ?
Does they need some tweaks ? some things to do before getting some good sound ?
hoka
all of these will work, but you can also consider running Charlize on a lead acid battery. that works great for me!
Page generated in 0.041987895965576 seconds with 17 queries,
spending 0.00896978 doing MySQL queries and 0.03301811 doing PHP things.
